Results 1 to 3 of 3
Thread: Delta LA200 midi lathe
    San Antonio, Texas
    765
    Ok, guys, the start capacitor on my Delta midi crapped the bed yesterday afternoon. Delta no longer makes the part, but I know I should be able to find a suitable replacement somewhere. The problem is, I don't know the specs and while I haven't had time to take it apart to check, every post I've read on just about every site says Delta didn't mark the farads and volatage on them. So this brings up a few questions:
    1) Does anyone know the specs for this?
    2) Where can I find one?
    3) For now I can spin start the motor, but will this hurt it?
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Southeast Pa
    2,019
    Well the answer seems to be 30 micro farad at 330 v or so. Now there seems to be some confusion as to whether this is a "start" or "run" capacitor. If it is a run there will be no centrifugal switch and you need a more expensive capacitor. If it is truly only a start capacitor then they are a dime a dozen so to speak. For a good oil filled run capacitor I would start looking at Surplus Center..
    But if price isn't a concern you should be able to pick one up today at any motor rewind shop. If you have the centrifugal switch you need to make certain it is clean and functional.
    Aug 2008
    Reno, Nv
    3,632
    I checked with a couple of forum friends and this is not an uncommon issue. According to them, any motor shop should be able to have you spinning in no time with $$ left over for Christmas!! This does support an old saying "Friends don't friends buy Deltas!" I always thought it was a flying thing
  1. Delta 10" midi lathe motor
    By Billy Burt in forum Turning Tool Questions and Show & Tell
    Last Post: 10-23-2012, 03:24 AM
  2. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  3. Delta 46-460 Variable Speed Midi Lathe
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 03-05-2010, 05:18 AM
  4. Delta Midi lathe for sale
    By Dale Johnson in forum Old Ads
    Last Post: 03-07-2008, 08:52 PM
  5. Delta Midi Lathe
    By Billy Burt in forum Hot Deals
    Last Post: 03-06-2007, 04:03 PM
