Results 1 to 10 of 14
Thread: chair repair question
    17,471
    i have got 2 chairs dropped off to repair maybe!!!! they have brk spindles that keep the legs together and the tenons are both broke off in the legs.. anyone got ideas of how to repair them? i dont own a lathe so other solutions needed as these also have a spindle going back tot he back rung of the chiar also.. pic is below...
Name:	chair fix-spindle 002.jpg
ID:	71085Click image for larger version.
Name:	chair fix-spindle 001.jpg
    my thoughts on how to fix, possibly drill a hole threw leg and into the spindle to glue a dowel into to connect the two.??? then refinish to match as close as i can.. the husband already tried to screw them together but he missed on two occasions and the misses wasnt to happy
    30,008
    IMO, the best solution would be to find a turner who can replace the broken spindles. (I'd offer to do it if my lathe wasn't 800 miles west of me right now.) I think anything less than that is gonna look patched.
    17,471
    well they have looked broke for alost twenty years from what i was told and those screws do add some artist look to it ok will need to find a turner close by.. or maybe i can mail them off and get them mailed back??? they are maple..
    12,247
    Yuup what Vaughn said....
    or as Dad said " Job worth doing is worth doing well or not at all"
    Sent from my MB860 using Tapatalk 2
    new york city burbs
    10,188
    Im wondering if the amount of time and effort needed to do the job right, turn a spindle, drill out the old spindle, finish to match, is worth it if the chair itself might not be worth as much as the repair.(if its a family heirloom, I dont think the husband would have used screws)
    that spindle doesnt look that complicated for a turner.
    Human Test Dummy
    17,471
    any turners want to give me a price on making two of these broke spindles? and send them in a flat rate box to me?
    3,132
    Larry i would do it, but around here it's real hard to find any Maple.
    5,320
    If there are already screw hols through the legs into the (broken) spindles, then I through drill them for a dowel. Figure a way to hold the spineles in place, then drill thru the leg, the broken off tenons, and into the end of the spindle, then put a dowel of the proper length in. Maybe leave the dowel an eighth or quarter inch long, and round over the end to look like a 'button.' ...Or, you could even use a steel (bolt) or aluminum rod toadditional strength, and sink it deep enough that you could use a dowel or button plug.
    Not as elegant as turning a whole new spindle, but neat, clean, and effective. Cheaper, too!
    Note, I'd only do this for a chair with little value - certainly not on a real antique!
    17,471
    these arent high dollar antigues, and buy doing a repair like jim suggested i dont have to match color as much..
    10,604
    I've had a couple of chairs like that over the years. Drill and dowel worked well for me.
  1. Chair repair
    By Gary Rubendall in forum General Woodworking Q&A
    Last Post: 06-03-2014, 07:23 PM
  2. Chair repair
    By Gary Rubendall in forum Flatwork Project Showcase
    Last Post: 06-03-2014, 10:31 AM
  3. Chair repair con't.
    Last Post: 06-03-2014, 01:21 AM
  4. Need help with chair repair
    Last Post: 03-03-2010, 06:09 AM
  5. Hey Don! I Found You a Chair Repair Project
    By Vaughn McMillan in forum General Woodworking Q&A
    Last Post: 11-18-2009, 07:16 PM
