Results 1 to 6 of 6
Thread: stuck screw with a twist
    Hi All
    I have a wood screw that is stuck in the wood. The screw is undamaged--head and threads are fine, however the wood inside the screw hole is stripped out so the screw spins freely and has no 'bite'. I can't use a bit for a stripped screw because it can't get a bite on the screw. It's stuck in some expensive wood that I don't want to tear up. Any thoughts??
    thanks,
    Dan
    13,364
    A drop of superglue on the tip of the screwdriver.
    3,132
    Dan Can you get something under the head of the screw, and pry up on it as you try backing it out?Some times all it takes is a little pressure to get it in a different spot and it will come out for you. Have done that a lot with good results.
    Dec 2008
    Portland, Oregon
    1,898
    +1 on the Superglue
    Jesus was a Woodworker
    I have super glue, and the screw does not show, so I can pry on it. win win.
    Thanks
    Feb 2012
    2,749
    Wouldn't have thought of that in a month of Sundays! Thanks, Brent. I run into that problem occasionally.
    Cheers,
    Roger
  1. getting stuck tractor out of mud in Norway
    Last Post: 07-17-2011, 09:55 PM
  2. A little hope for those still stuck in winter
    Last Post: 04-12-2011, 01:28 AM
  3. Head stuck in a chair
    By Dan Gonzales in forum Off Topic Discussion
    Last Post: 12-19-2009, 03:21 PM
  4. Should have stuck with the piano lessons
    By Chuck Rodekohr in forum Off Topic Discussion
    Last Post: 11-07-2009, 04:07 PM
  5. Slightly Stuck
    Last Post: 03-02-2008, 10:27 PM
