Results 1 to 10 of 10
Thread: sanding tiger maple
    sanding tiger maple
    I'm working on a shelf project with tiger maple. This is the first time I have used this wood in more than a few small trim pieces. I'm getting down to the final sanding and I can't seem to get the sanding marks out of it. I have carefully run through the grits in succession up to 320. I typically have used BLO to pop out the grain by sanding it into the wood with 320 (never heard of anyone doing this but it has worked for me...). Like I said though, I have typically used small pieces of tiger and the sanding marks went away when I put the oil on. I'm wondering about on the larger surfaces. Is there a a better way to sand/smooth tiger maple? Do I need to keep going higher with the grits? I plan on having a medium to med/high sheen.
    Thanks
    Dan
    May 2011
    Cape Cod, Ma.
    1,553
    how are you sanding it Dan? by hand or with an ro sander? Also, big key point. if you see the sanding marks still then you didnt sand the scratches of the prior grit out completely with the next grit. ie the 150 didnt get all the scratches out that were left by the 100 grit. you will need to go back to that grit again and work it. one thing to be careful of with tiger maple and figured wood like that is that the "stripes" are a different hardness and you can get a ripple effect if you oversand or your sanding pad is not stiff enough to ride over the soft spots. any hand sanding should be done with the paper on a block of wood to prevent or at least minimize it. good luck! hope this helps and post pics!!!! oh also, denatured alcohol will help you see any sanding scratches that are left and bring out the look of the grain without raising it.
    Rich
    I agree that you have make sure you've sanded through each grit. The point I'm at now I have tested to make sure I'm sanding at the current grit by changing direction a bit, and I can see the marks change with no underlying larger marks. Maybe I'm using too much pressure. I use a RO sander up to 220, then go by hand/eye.
    11,833
    That could end up as a very fancy shelf.
    Figured maple is popular with builders of traditional style rifles. Some use broken glass to scrape smooth. Very tedious process.
    Others wet the surface between sandings. There are as many favorite sanding materials as people who do this. Wet/dry automotive paper is used as a many others.
    Try wetting the sand with fine paper on a block. Take yer time.
    On figured woods I stop sanding around 180 till I get the first finish treatment on. Much finer and you hide all that beautiful "pop". I'm not quite clear on which sanding marks are causing the issue. In your first post you state that you cannot get the sanding marks out; OK, I'm good with that. In your second post you say that you are making sure that before changing grits, you have a consistent scratch pattern laid down with "no underlying larger marks" being left from the previous grit; here's where I get confused.
    I think you are saying that you are getting machine marks from the 320 that you are finishing up with via the ROS, yes? If this is it, and you want to go to 320 before starting to finish (I go even finer sometimes for specific reasons) Once you have a consistent 320 pattern, set the ROS aside. Put a quality 320 grit paper on a decent sized flat block (2-1/4" x 9" or there-a-bouts) and sand with the grain. This should convert all your swirl marks to directional marks without having to remove too much more material. If you haven't yet, you can wipe with mineral spirits and cross-light the surface to look for any unwanted survivors.
    At 320, in a light hardwood like maple, your swirl marks should be very near undetectable unless you are going dark on the colorant. You may want to look at some reviews on ROS, check you pad, change paper more frequently, etc. You mention pressing too hard. I don't press any harder than it takes to keep the sander controlled. Let the abrasive do the work. Otherwise you end up with inconsistent results . . . or I do anyway . I use a $50-$60 Bosch that won the pattern battles. Great price for a great little sander so, of course, they discontinued it
    Here are few pictures. Got assembly done today and it is ready to finish sand and put down finish coats. Don't intend to put any color in the maple. The edge trim is purple heart, the 'keystone is ash burl, and the insets are slate from roof tiles.
    Attached Thumbnails Attached Thumbnails IMG_0037.jpg   IMG_0050.jpg   IMG_0049.jpg
    Very cool, Dan.
    17,475
    never seen ash burl like that before its gorgeous! and that shelf is a knock out.
    4,699
    Well I can't say much about the rest of it cause I'm to busy looking at that ash burl! That is really nice stuff, really steals the show for sure.
    Thanks
    The ash is a turning block that I cut slices out of.
  1. did I turn the tiger off it?
    Last Post: 08-14-2015, 10:15 PM
  2. Shaving a Tiger?
    By Jim DeLaney in forum Handtool Project Showcase
    Last Post: 02-15-2012, 08:28 PM
  3. Tiger Maple
    By Steve Ash in forum General Woodworking Q&A
    Last Post: 07-09-2010, 07:13 PM
  4. Tiger Maple Box with Custom Hinges
    By Jason Tuinstra in forum Flatwork Project Showcase
    Last Post: 03-05-2008, 09:08 AM
  5. Tiger Maple Hutch
    By Chris Barton in forum Flatwork Project Showcase
    Last Post: 12-01-2007, 02:12 AM
