Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Walnut doors with stained glass inserts -COMPLETED
    Toronto, Ontario, CANADA
    2,332
    In early 2010, I built two pairs of walnut doors and inserted stained glass panels that I made into the doors. I described that project on-line but it seems that I did not describe it in the Family Woodworking forum. If I did, I certainly can't find it here. For a description of that project with lots and lots of pictures and detail both about the doors and the satined glass, you can look at the Festoll Owners Group forum thread: http://festoolownersgroup.com/member...stained-glass/Margaret really likes the doors and she wants a matching pair for the passageway between our kitchen and dining room. This project in now underway and I hope to complete it before the end of November. Regular reporting upon progress seemed to make the first project proceed well, so I am going to report here on the new project too -but in less detail because the majority of the steps will be much the same as in the first project.Two weeks ago, I finished building the six stained glass panels that will be required. They have the same design as the panels in the original set of doors but are slightly smaller because the new doors will be narrower. Here is photo of one of the panels after assembly but before soldering:Click image for larger version.
Name:	Walnut and stained glass door for kitchen  -First panel is ready to be soldered.JPG
ID:	71180And here the six panels are layout out in their approximate locations on the old doors that have been removed:Click image for larger version.
Name:	Kitchen to Dining Room door project 01 -Rough layout of new doors -small.JPG
    Cheers, Frank
    868
    I have seen the original walnut door/stained glass project first hand. Quite amazing transformation of the doorway, but nothing more than I would expect from Frank!
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    13,453
    Great job on both the doors and stained glass Frank.
    10,604
    Looking forward to watching your progress Frank.
    Ditto here.
    2,332
    Week ending October 21st: (post one of two)
    I did get started on the replacement doors. Here the old door frame is being removed:
Name:	Kitchen to Dining Room door project 02 -Starting to remove the old door frame -small.JPG
ID:	71181 Click image for larger version.
Name:	Kitchen to Dining Room door project 03 -The old door frame has now been removed -small.JPG
    Getting our kitchen into this kind of state is a define commitment to Margaret on my part to complete this task ASAP.
    The first step in constructing the new doors was to re-saw a sufficient supply of 5/4 walnut boards:
Name:	Kitchen to Dining Room door project 04 -Re-sawing rough cut walnut boards -small.JPG
ID:	71183 Click image for larger version.
Name:	Kitchen to Dining Room door project 05 -Re-sawn walnut boards awaiting further processing -small.JPG
    These were then planed to a uniform thickness of 1 centimetre:
Name:	Kitchen to Dining Room door project 06 -Planing re-sawn walnut boards -small.JPG
    It is a real joy to use my new Hammer A2-31! I find it hard to believe that it is possible to dial to a tolerance of about half a millimetre. I bought the machine for its space saving but, now that I have used it for a little while, the ease of use and quality of cut is at least as important.
    As I did with the other doors, most of the walnut is being laminated to Baltic birch. Here one such “board” is being laminated:
Name:	Kitchen to Dining Room door project 07 -Walnut laminated to Baltic birch to form peices used for.JPG
    Cheers, Frank
    2,332
    Week ending October 21st: (post two of two)
    The overall quality of the walnut is quite good, but there are a few knot holes. I deal with these using a mixture of walnut planer shaving, walnut sawdust, and epoxy (QuickCure 5) in steps as shown in the photos below:
    (1) Click image for larger version.
Name:	Kitchen to Dining Room door project 08 -About to mix material used to plug knot holes -small.JPG
    (2) Click image for larger version.
Name:	Kitchen to Dining Room door project 09 -Mixing material used to plug knot holes -small.JPG
    (3) Click image for larger version.
Name:	Kitchen to Dining Room door project 10 -Knot hole has been plugged -small.JPG
    (4) Click image for larger version.
Name:	Kitchen to Dining Room door project 11 -Filled -n knot hole has been sanded -small.JPG
    The mixture dries very hard and can be readily sanded. Once a finishing coat is applied (later), the former hole blends in reasonably well.
    The walnut is screwed as well as glued, then the screw holes are plugged with walnut dowels. These are “manufactured” from cut offs:
Name:	Kitchen to Dining Room door project 12 -Creating a lot of walnut plugs -small.JPG
    Here, boards are being installed around the door frame:
Name:	Kitchen to Dining Room door project 13 -Attaching laminated walnut pieces to door frame -small.JPG
    I just noticed when looking at this photo now that I chipped then paint off a couple of tiles when taking off the old molding. Oh well, I still have most of a box of tiles left over from when I applied them about 25 years ago. I expect that I will need to purchase new grout though.
    Cheers, Frank
    2,332
    Week ending October 28th:
    I made slow but steady progress on the door project this week. The first thing that I did was a job that I hate and that is puttying all the windows. This has to be done in order to stop the glass pieces from rattling around in the enclosing lead came channels. The job is dirty and time consuming and it seems to take days before all the excess putty is removed. In the photo below putty has been applied to one side of one window.
Name:	Kitchen to Dining Room door project 14 -Puttying all the windows -small.JPG
    The putty next has to be brushed into the small openings between the glass and the lead. Then it is (mostly) cleaned off the calcium carbonate powder.
    The doors will have a (15 mm) Baltic birch plywood core. In the photobelow, the cores are being tested for size in the opening:
Name:	Kitchen to Dining Room door project 15 -Testing the plywood core of the doors for size -small.JPG
    The glass panels have not been installed yet; they are simply being temporarily held in place with some thin plastic shims.
    Neil C on the Festool Owner’s group forum suggested that I make some molding with a dado in the back to overlay a bit of the tile and, thus, cover up the chips that I created when removing the old molding. This sounded a lot easier that re-tiling, so I created a small sample to test out the idea:
Name:	Kitchen to Dining Room door project 16 -Sample molding for kitchen side of door frame -small.JPG
    I like it, so I made molding to go all the way around. Here is a photo after the piece on the right hand side of the door frame has been screwed in place:
Name:	Kitchen to Dining Room door project 17 -One piece of molding has been installed on the kitchen s.JPG
    Cheers, Frank
    10,604
    Great tip on the molding
    I can sure see what a time consuming job cleaning up all that putty would be
    Looking good so far
    Stained glass looks awesome, nice job
  1. Stained Glass, Demo Notes (hand out from Burning Wood)
    By Darren Wright in forum Tips and Tutorials
    Last Post: 10-06-2014, 06:27 PM
  2. Oak floor lamp with stained glass shade -Build thread
    Last Post: 12-06-2012, 05:49 PM
  3. So what do you guys pay for the glass inserts
    By Don Baer in forum General Woodturning Q&A
    Last Post: 11-05-2010, 12:12 PM
  4. Stained Glass - Getting started
    Last Post: 02-03-2008, 03:58 PM
  5. Installing glass in cabinet doors
    By Tom Williams in forum Carpentry and Construction
    Last Post: 08-25-2007, 09:54 AM
