Results 1 to 10 of 18
Thread: Frame for a Wedding Present
    I've been taking care of a long list of little items that has backed up. This is the inside trim for an 11" x 14" wedding picture. This is only the inside trim portion but, it had such a sweet curl in the maple, I had to share it early .
Name:	Tyler Frame (3).jpg
ID:	71270Click image for larger version.
Name:	Tyler Frame (1).jpg
ID:	71268Click image for larger version.
Name:	Tyler Frame (2).jpg
    Independence, Kentucky
    1,354
    Wow ! that's some pretty Maple looks great What finish did you use?
    Thanks Charles. The finish protocol is sand to 400 grit, flood with 1:1:1 of BLO, mineral spirits and varnish. I use a phenolic modified / alkyd resin varnish from Cabot's lately. Flood the surface and let sit 20 minutes or so. Wipe completely dry and flood again. Let sit an additional 20 minutes or so and then rub it off as if you've changed your mind. Wait 30 minutes to an hour and go back and wipe it again. Monitor (and wipe any weeping if necessary; probably not so much on maple, lots on mahogany though) a couple times a day for a few days. There is a long cure period on this finish but, I do enjoy the result. The outer frame will be walnut oiled dark. I will supply it with a mat for 11 x 14 and an 8 x 10 as we cannot get a commitment on size. Ah, youth .
    San Antonio, Texas
    765
    Beautiful frame, Glenn!!!
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    30,014
    You're just teasing us, man!
    Sent from my iPhone using Tapatalk
    10,604
    Sure is some pretty wood
    17,471
    you must have paid a pretty penny for that much curl glenn
    Oddly enough that section came out of a stack of maple I had picked up for secondary wood. I noticed the caramel colored ripples along the edge of one board and re-sawed into it and there it was ;-)
    13,439
    Great looking frame and figure. Found a similar gem a few years back that I still have some of. They had it stacked and priced with the regular maple.
    Jun 2007
    4,944
    That is one beautiful hunk of wood Glenn. I'm eager to see the final result when it is contrasted against the dark walnut.
    Enjoy,
    JimB
    VOTING MEMBER
  1. first wedding plaque
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 10-19-2015, 02:55 PM
  2. Another Wedding Day!
    By Pete Simmons in forum Off Topic Discussion
    Last Post: 06-25-2008, 12:10 PM
  3. Wedding day!
    By Steve Ash in forum Off Topic Discussion
    Last Post: 06-23-2008, 10:40 PM
  4. Pole frame / Post Frame construction question
    By Lincoln Myers in forum Carpentry and Construction
    Last Post: 10-19-2007, 10:54 AM
  5. Wedding present
    By John Whittaker in forum Flatwork Project Showcase
    Last Post: 04-25-2007, 10:54 AM
