Results 1 to 10 of 11
Thread: New Marking Gauge
    Jan 2012
    Gonzales, Louisiana
    115
    New Marking Gauge
    I found myself in need of a mid size marking gauge for milling rough lumber (by hand of course) so I mocked this up. It needs a better screw and knob as well as some overall refinement but I'll likely build a new one and still use this one.
    It's cherry, mahogany and curly pear. The knife is O1 steel and needs a bit more camber before I harden the cutting edge. it's pretty hefty and can mark up to about 20" wide.
    I should have taken pictures along the way but it was a little de-stress project and I was so in the zone I just busted it out in a couple hrs.
    It has a captive block of cherry inside the gauge that applies pressure to the beam when the screw is tightened.
    Thanks for looking.
    Attached Thumbnails Attached Thumbnails image-3376575194.jpg   image-3158346919.jpg   image-877674899.jpg   image-3887042861.jpg
    5,172
    Cool, Tom. But how do you control the cutting end of the beam? Seems like it would want to drag.
    Jan 2012
    Gonzales, Louisiana
    115
    The knife sits about 1/64" lower than the bed of the fence, pulling it in a back and forth motion as you go cuts a nice line pretty quickly.
    In other words, you can use it one handed with no trouble as the fence is wide enough and the beam is rigid enough to keep it on track. Also the bevel of the knife is on the inside keeping it from wandering inwards.
    Does that answer your question? I may have misunderstood what you are asking.
    Mar 2012
    SW Minnesota
    159
    One more time! Nice work Tom.
    I used an Exacto blade in the gauge that I built; It does tend to wander a bit. I think I will try beveling the blade to one side only to see if that stabilizes things a bit.
    Jan 2012
    Gonzales, Louisiana
    115
    Quote Originally Posted by Dennis Ulrich View Post
    Thanks, Dennis.
    The knife will try to wander away from the bevel - because of the bevel. A chisel edge with the bevel towards the fence makes it try to pull away from the fence, as it can't, it's helps keep it tracking straight instead. so I think you would see an improvement if you did that. I grind a slight bevel on pin marking gauges rather than a pin point for this same reason.
    Also a cambered edge performs better than a spear point because it progressively cuts deeper, again reducing the pins tendency to wander.
    5,172
    Cambered meaning tilted? As in the cutting edge tilted slightly back? How about a close up photo, Tom? I really want to make one of these because I have always had so much trouble with them.
    Jan 2012
    Gonzales, Louisiana
    115
    By cambered I mean like the camber on a plane iron. The iron is as close to 90 degrees vertical - close as I could get it using a breast drill, lol.
    Look at the cutting edge on the picture above again. It's a crescent shape. I'm at the FD today and I'm out on the road now but I'll try to get a mote explanatory picture once I get back.
    Jun 2007
    4,944
    That has a real light spirit. It looks like a useful piece of fun. I like it.
    Enjoy,
    JimB
    VOTING MEMBER
    Jan 2012
    Gonzales, Louisiana
    115
    Carol, I did my best to get a better picture of the knife. Does this better answer your question?
    5,172
    Thanks, Tom. That did it.
  1. Marking gauge conversion kit to mortise gauge
    Last Post: 09-03-2010, 03:55 AM
  2. FS: Nice old Stanley marking gauge
    By ken werner in forum Old Ads
    Last Post: 05-31-2009, 08:06 PM
  3. Replies: 8
    Last Post: 05-31-2009, 01:02 AM
  4. Added Purpose for my Marking Gauge
    By Jerry Palmer in forum Neander Tool Questions and Show & Tell
    Last Post: 07-19-2008, 10:34 PM
  5. FS: Crown Mortise Marking Gauge - **SOLD**
    By Doug Shepard in forum Old Ads
    Last Post: 01-21-2007, 04:08 PM
