Results 1 to 10 of 11
Thread: Questions about phenolic?
    I came across this piece of 1/2" x 61" x 81" piece of phenolic for free. I've had it for about 9 months and was wondering what to use it for. I'm amazed that it's still flat considering when I got it it was leaning against a wall for a bout a year before I got it.
ID:	71372Click image for larger version.
    Any ideas on the best way to cut or machine it?
    The 3/4" piece I got for my out feed table top was a bugger to cut with the skill saw and a sharp carbide tipped blade. Smoothing the edge with a straight router bit was also a chore.
    4,552
    Router table tops. They will never wear out or sag. Yer a lucky man to have found that it is off the wall expensive
    A Turn N Time
    Frog Pond Guitars
    17,472
    you do have a high dollar piece of material and router top was my first thought as well but any tabletop be it a chop saw station or another use would be great use of it..
    I was thinking the same thing on replacing the top on my router extention wing with it along with some table saw inserts.
    The other piece I have is 3/4" thick and I used it on my out feed table.
ID:	71381Click image for larger version.
    It was a bugger to cut and machine and was wondering if anyone had any helpful hints or an easier way to cut/machine this material?
    Should I use a triple chip saw blade?
    What about tooth count?
    Would a spiral router bit cut it easier?
    Jun 2007
    4,944
    I have a piece of 3/4 inch. It is too big. It gets in the way. It is too good to use for something trivial.
    It is like an older computer. Too good to throw away but not good enough to use.
    Enjoy,
    JimB
    VOTING MEMBER
    Jan 2011
    3,798
    Don't know if it's the same stuff you have, but we cut a piece down at the frame shop I worked at with a diamond blade on the circular saw...the stuff we had was referred to as Bakelite, tuff as nails and produced some nasty dust. No idea for curve cuts or interior cut-outs as in for a router plate etc.
    http://www.homedepot.com/buy/7-in-di...l#.UJEXK1Kls_5
    Oct 2009
    Dennison, MN
    512
    Looks very heavy and dense. Is it? I've got zero experience with the stuff.
    "Do, or do not. There is no try."
    -Yoda
    17,472
    Quote Originally Posted by Karl Brogger View Post
    KARL ITS THE SAME STUFF THAT YOU SEE ZERO CLEARNCE INSERTS MADE OUT OF OR FACTORY BUILT ROUTER TABLES. sorry hit cap lock key not retyping its heavy and stays flat.
    Toronto, Ontario, CANADA
    2,332
    I'm planning to purchase a piece of the stuff to replace the beat up material on my General 650 table saw extension. I wonder how much it is going to cost and if I can purchase it pre-cut to fit. Right now, I don't even know who sells it in the Toronto area.
    Cheers, Frank
    17,472
    frank plenty of distributors LINK
  1. Phenolic tapped holes
    Last Post: 03-29-2014, 09:31 PM
  2. Phenolic of UHMW in Thin Sheets?
    By gary curtis in forum General Woodworking Q&A
    Last Post: 01-04-2009, 02:36 PM
  3. Anybody here interested in a small phenolic sheet?
    By Mark Rios in forum Hot Deals
    Last Post: 08-31-2008, 08:16 PM
  4. phenolic plywood
    By Doug Sinjem in forum General Woodworking Q&A
    Last Post: 05-09-2008, 08:56 PM
  5. Questions
    By Jack Tanner in forum General Woodturning Q&A
    Last Post: 03-10-2008, 01:01 AM
