Results 1 to 10 of 21
Thread: combination sanders
    Jun 2010
    3,220
    combination sanders
    Hi all:
    I've been looking at some of the small combination sanders, you know, one with a small belt and the round flat thing. Could someone kindly explain to me what the flat round sander is for? I understand what the belt is for and I understand what the spindle is for, but I can't figure out what you would use the flat round one for.
    thank you all
    AKA The Rookie
    NH
    4,005
    Ummmm sanding
    I am assuming you mean a disk sander like this http://www.grainger.com/Grainger/DAY...121103003339:s
    I use mine for small parts and if you have the table set up right it works good for things like rounding the end of a flat handle while keeping it square to it self.
    Stupid hurts.
    May 2009
    Poway, CA, near San Diego
    174
    Hi folks,
    In my opinion, a disk sander is much more useful than a belt. I have one of the combo ones and rarely use the belt. The disk has a table with miter gauge slot. Also, you can just clamp a stick at any angle you want. The belt part usually has a small, hard to adjust "fence"/stop that might keep the board from flying away, but not much else.
    Good luck,
    Bob
    As mentioned, a disc is ideal for controlled sanding up to a line or sanding a curve onto something while maintaining the material at a particular angle. It is also good at adjusting miters when used with a miter gauge. Belts can sand flat faces on a box or other object. Again being most useful with a good table and / or miter gauge. My 4 x 36 belt / 6" disk combo got much more use out of the belt than the disk as you can only use about half of the disk's size. I did, however, build a better table platform for it. A large belt like an edge sander (6 x 80 or so) has been extremely useful to me. My recent 12" disk acquisition has brought the disk sander into a position of usefulness as well.
    Here's a good example of using a disk(although not for wood) and PLEASE be aware this disk is turning in the opposite direction of most I have come across. You always sand with the disk direction moving the paper past your material and toward the table. Using one the other way would be like running your bandsaw in reverse with the blade teeth pointing up ;-)
    3,134
    You always sand with the disk direction moving the paper past your material and toward the table. Using one the other way would be like running your band-saw in reverse with the blade teeth pointing up ;-)
    I wondered what was wrong with your band-saw....
    Jun 2010
    3,220
    Thanks folks. I was surprised (and disappointed) to see that the spindle is never in combination with the others, but is more expensive and you have to buy it separately.......but at least I understand now the disc....
    AKA The Rookie
    30,009
    Sometimes the spindle sander has a belt attachment:
    Ridgid Belt/Spindle Combo
    Jun 2010
    3,220
    Thanks Vaughn. Never saw that before. Do the spindle sanders have different size spindles?
    AKA The Rookie
    NH
    4,005
    Quote Originally Posted by Cynthia White View Post
    My jet has several different size spindles.
    And I have used everyone of them. That has got to be one of the best sanding investments I have made to date.
    http://www.northerntool.com/shop/too...FcuZ4AodlFIADw
    Stupid hurts.
    30,009
    ...Do the spindle sanders have different size spindles?
    Nearly all brands come with several spindles in an assortment of sizes. The Ridgid has the five you can see in the photo, plus the (relatively small) belt that also oscillates up and down like the spindles. There are a lot of happy hobbyist owners of that sander (including me), but I wouldn't consider it robust enough to be used daily in a pro shop. The sander Chuck showed is more of a pro machine.
  1. Uncommon/rare Combination Saw Found
    By Matt Hutchinson in forum Neander Tool Questions and Show & Tell
    Last Post: 10-29-2015, 11:52 PM
  2. Which combination square?
    By John Daugherty in forum New Tools
    Last Post: 03-26-2011, 04:03 PM
  3. Masterlock combination
    Last Post: 03-07-2011, 11:43 PM
  4. Stanley 55 combination plane.
    By Bill Green in forum Old Ads
    Last Post: 02-23-2011, 02:09 PM
  5. Storing Combination Squares
    By Mike Henderson in forum General Woodworking Q&A
    Last Post: 02-02-2008, 05:25 PM
