Results 1 to 10 of 11
Thread: Another whoseewhatchacallit
    4,699
    Starting with the pieces this time and will try to update as I make progress
    First off 36 vaguely similar pegs and two curious schnauzers.
    These were sized with the go/no go gauge I just posted about in the jigs & fixtures (I used one end set at 3/4" for the main dimension and the other end at 1/2" for the tenons). They aren't all perfect by any means but it was a lot of good skew^Wsanding practice... After sorting and rejecting I'm hoping to get 24 nice ones for the project.
    San Antonio, Texas
    765
    Well, I for one am curious to see the updates.
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Catalunya
    4,632
    Although I'm curious about the pegs, I like the schnauzers more, I wish I had a giant one.
    Best regards,
    Toni
    Jun 2007
    4,944
    I think they are handles for those mop like things that they clean toilets with.
    You got two dozen toilets in your house?
    I'm curious also!
    When we lived in the avocado orchard in Fallbrook, CA, the lady behind us had a schnauzer. That was the most loving animal that I ever encountered. It went into absolute rapture when I petted it.
    The lady cut down all of the avocado trees in back of her house, all of the trees that the schnauzer could get to, that is. Seems the dog loved avocados. If one fell on the ground, it vanished---right into schnauzer's mouth. The dog was getting fat so she cut down the trees.
    Enjoy,
    JimB
    VOTING MEMBER
    4,699
    Funny, I didn't think ovacados were good for dogs, apparently that one was ok with it (and well.. I see dogfood with it in it now that I think about it). I sure like them either way
    So at this point I'm going to have to exclude Mr Gallian from guessing, sorry Paul but you have to admit it would be unfair
    Got some pieces cut and some bracing glued up on the ends for later. The curves were cut with the bandsaw, cleaned up on drum sander and then tidied up by hand with a chisel and some sand paper.
    Holes were drilled and slots were cut.
    On all the pieces (sorry about the image quality)
    Some locking knobs where turned and some #8 machine screws had their heads lopped off and were epoxied in place. Not quuuittte the same, but close enough I suppose (grumble).
    Some 1/4" rod was marked
    And drilled/tapped to accept the machine screws.
    Darn close to dead center. The cross slide vice really helps here. Its the uber quality $45 HF special and has more backlash than a poorly run election, but is a heck of a lot better than not having it.
    One knob assembly. MuHahaha (I was going to count to four, but you can fill that in yourself .. two knob assemblies.. muahaha..)
    Frame "dry run". Seems to be fairly sturdy.
    Close up of how the ends go together.
    4,699
    Back to the pegs. I wanted a nice close fit so had turned them a weee bit over sized. A quick homemade dowel plate (drill a 1/2" hole in a piece of metal, leave the slight burr from the drill bit raised on the top side as a cutter). Drive the tenons through them and voila a perfect (or close to it anyway) fit.
    The Schnauzers still have no idea whats going on.. but that's fairly normal for them
    I think your wife will put this to good use. I just nailed the boards with pegs to a wall in my shop and my wife uses it without complaint. She never uses any of the portable ones. If I had the ability as you do I would give it a try. Well done! Do you think Star Trek uses one to move real fast? Warp 3 Scotty.
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    4,699
    Quote Originally Posted by Paul Gallian View Post
    Thanks Paul, we'll see on the functionality of the final product once the rubber hits the road and its put in use. Pretty is pretty, but its really meant to be used (I have a couple of remediation strategies for the few failure modes I can foresee, but am hoping they aren't needed). I would definitely bet that your solution is more functional (and certainly more sturdy), the main reason I'm doing all these convolutions is so its easier to store and more portable. I might also make a smaller more portable version as there has been talk of desire to go to some workshops (although the amount of equipment that has to go to those already makes me wonder if its worth the bother )
    Also please don't over think/shoot any "abilities" I might (or more realistically might not ) have here either, there is a lot of gosh and by golly happening in between the updates otherwise something simple like this wouldn't be taking me three weeks to do. I made mock ups of just about every part here and have abandoned some stray pieces that didn't work out along the road (like the first 30 pegs that were to short - at least they are plausibly usable for other purposes.. coat rack anyone?). I'm pretty sure most anyone could make something about the same as this, most of doing is trying, failing, retrying.. at least that's how I do it.
    4,699
    Well I am nothing if not tardy on my updates here.
    First I split the tenon on the pegs. I did this using a V holder on the bandsaw and carefully sliding the pegs into the blade. Shift the V holder over a blade width and a smidge and repeat. Finally clean out the little tag in the middle.
    Cut a bunch of small walnut wedges to match the slots, nothing complicated just left them rough from the bandsaw (imho they grab better that way).
    From there it was just more assembly. Tap the pegs in place with some glue (careful to line up the opening the right way, I had a couple a little off and when they're tightly fit they're a bear to rotate), hammer in the wedges with more glue. Let it all dry, then flush cut, plane, sand..
    Ends up something like this:
    Here is the whole thing laying on its back on the floor.
    Stood up and "in use" (ok test use - I have no idea what I'm doing for this part ). Pardon the mess, I've been patching my trousers in preparation for winter, the holes in the knees are cold.
    At this point its "done" although I still want to make a stand assembly to make it easier to use and a hanging rack to hang all of the pieces from when its not in use.
    So to be fair since I can't imagine someone figuring this out if they didn't know what I was doing at all, here are some hints:
    • no it has nothing to do with the beer fridge behind it
    • Yes it has something to do with weaving (the "stand" will actually just be a couple of small brackets to attach it to a loom.
    Looks very functional and pretty too
    My wife would like to see a photo of your loom warped and weaving..
    thanks paul
    still sings!
