Results 1 to 8 of 8
Thread: I think it's toast....
    2,784
    I was mowing Sat before dark, just the back yard, when clatter, clatter, clatter, pop, pop....pop, and the engine died. A little background, this is a mower my Dad gave me 3 years ago, I have no idea how long he had it before then, probably 5 at least. Craftsman hydrostatic with a Briggs & Stratton single cylinder 17 hp motor. It had always started rough like something was rubbing, but would start and ran fine. Oil leaked badly, but hey, not a big deal. Well, I went ahead and opened it up and found some chunks of metal in the lower engine. Pulled the head off and this is what I found:Click image for larger version.
Name:	mower engine dscn3175.jpg
ID:	71609 Looks like what was rubbing was the intake valve, and it finally broke, dropping the valve head in the combustion chamber. The pieces of metal I found in the lower end was parts of the piston top.
    I think the lower end is probably ok, but I wouldn't trust the head. So, new piston and head? Not sure it's worth it. I have a push mower that threw a rod a bunch of years back. I can get a new engine for it for about 130.00. LOML used to mow with it. Hmmmm........Jim
    Coolmeadow Setters...
    Exclusively Irish!
    10,604
    Yup, it's toast
    Independence, Kentucky
    1,355
    Yep and it's burned toast at that!
    Sep 2007
    Plainwell, Michigan
    4,857
    Ahhhhhh, just throw some duct tape on it and throw it back together.........Yep, toast
    Dec 2008
    falcon heights, minnesota
    5,610
    i've found the perfect replacement! no valves to worry about! no gaskets!
    benedictione omnes bene
    www.burroviejowoodworking.com
    if the duct tape does not work -- try some JB-Weld
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Oct 2007
    Les Coteaux,Quebec
    68
    But now with a lower compression ratio, you can probably crank it by hand
    Dec 2008
    Portland, Oregon
    1,898
    You should go with a Riding Mower
    Jesus was a Woodworker
  1. Is it toast?
    By Rennie Heuer in forum Neander Tool Questions and Show & Tell
    Last Post: 08-15-2015, 11:09 PM
  2. Holy moly....the euro is TOAST!
    By Joseph Shaul in forum Off Topic Discussion
    Last Post: 06-06-2010, 07:38 PM
  3. Nikon Toast - Ressurected!
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 01-20-2009, 11:52 PM
