Results 1 to 10 of 15
Thread: how much bend
    17,450
    how much bend
    ok great wize ones, how much can you bend manufactured plywood say 3/8" i have a project that should be vacume formed but after looking at the radius needed, i had question rather it could be made to conform with out the vacume process... the radius is slow curve of 16" with a drop of 4" in the 16".. would steaming make it conform or would i be further ahead to make the lamination? be nice tod ok i know i am ignorant
    Steve Clardy Guest
    Have you thought about saw kerfing the back?
    17,450
    great wize one ,cant do that its gotta look good on the back too
    head board.
    Baltimore, Mary land
    68
    Plywood...
    If you steamed plywood, wouldn't it de-laminate in the process?
    George Blevins
    Astriapo@earthlink.net
    Steve Clardy Guest
    head board.
    Hmmmm. Yer making it complicated Larry
    Steaming is out, as the glue will let loose.
    How about two layers of 1/4", slightly kerf both, then have the good sides showing?
    Only one glue joint that way.
    If you are not in a hurry, just rip, mill, or bandsaw 1/8" , and build you a glue-up form.
    Michigan
    2,436
    Throw it down yonder in the creek, then prop it next to the shop in the hot sun till it warps just right.....couldn't resist.
    Can't help you out on this one boss....
    Odessa, Tx
    1,813
    How about kerfing the back side and then vaneering that side after the curve is set, or as a lamination over a form?
    17,450
    that jist might work
    Quote Originally Posted by Steve Clardy View Post
    i think i could do that one, and not have a high rental few on a geat big bag but maybe i would be better off doing the bag though seein as this is 36" high and 60" wide that way i would eliminate the joint in the ply.. maybe i have no altercation but too???? pay rent
    Charlotte, NC
    1,487
    Take two 1/4 sheets. They will bend easily and glue them together. The glue should hold your bend and you can put the good faces out on both sides. It'll be a little thicker than what you were asking for, but you may be able to compensate for that.
    larry, one way to do what you`re askin` without a bag is to use 3 layers of 1/8" bending birch bent around a form.....when dried apply paperbacked veneer. minimal tools required using this approach....tod
  1. How to Bend Oak
    By David Agnew in forum General Woodworking Q&A
    Last Post: 02-06-2015, 02:24 PM
  2. Road to Mordor (or Bend OR)
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 07-13-2014, 12:17 AM
