Results 1 to 8 of 8
Thread: TBIII Set up time?
    5,533
    TBIII Set up time?
    Hi gang,
    I'm in the midst of yet another round of cutting boards, and am in the 'watching glue dry' phase, using Tight Bond III. Other than 'overnight' how long do you wait before you work on the piece again? I'm usually in the 'overnight' camp as well, but I've been watching Scott Phillips on the american woodshop and he mentions a really Short time span... as in just a couple of hours of set up time. more idle curiosity than anything, I'm perfectly happy to leave the boards I glued up this morning til tomorrow, but I wouldn't mind planing them down this evening (9 to 12 hours from glue up) if possible.
    -Ned
    Independence, Kentucky
    1,355
    Ned you would be safe to start planing them down in a couple of hours with out havig any problems with the joints. A complete cure, I would say overnight is more than sufficient I have heard of some cases of glue line creep, but I have only experienced it on one board that I did, and never did come to a conclusion as to why, so it's a non issue for me so far.
    10,604
    I usually wait overnight but sometimes my overnight wait ends up only being 10-12 hours. The only time I've ever had a problem was when I let a glue up sit for less than 4 or 5 hours.
    new york city burbs
    10,188
    even if youre glueing up in ideal conditions, meaning moderate temps and low humidity, there is no reason not to let them cure properly. whats the rush?
    You could plane down 6 boards in 10 minutes with the planer, so why risk any headaches.
    Human Test Dummy
    Oliver Springs, TN
    1,726
    If I'm in a rush I'll wait 3-4 hours. If not like Allen says I'll wait overnight. Now, If I glue early in the morning and get back at it 8 - 9 hours later I consider that "overnight".
    5,533
    allen,
    honestly, I'm Not in any hurry, I simply was asking because I didn't believe Scott's set up time. Like just about everyone here, I have no problem leaving it overnight.
    -Ned
    Central NY State
    3,374
    I've planed things that have set up for a few hours with yellow glue. Sometimes they held, sometimes they haven't. Now that I'm old and a little wiser, I try to wait overnight. But that's TB I or the Elmer's equivalent.
    new york city burbs
    10,188
    Quote Originally Posted by Ned Bulken View Post
    allen,
    I wasnt trying to be snooty.
    Im not sure if a joint would fail after 3 hours, but I feel why even make it an issue.
    Human Test Dummy
  1. Long time lurker first time member
    By James may in forum Welcome and Introductions
    Last Post: 01-29-2016, 06:36 AM
  2. Where My Time Goes....
    Last Post: 04-25-2012, 01:25 AM
  3. It's time for a Shed Thread -Time to get the roof on
    Last Post: 10-27-2011, 02:26 AM
  4. Wake Up,, its time to get back at it!!!,, we HAVE enough,next time
    By larry merlau in forum Giveaways, Contests, and Swaps
    Last Post: 01-12-2010, 12:37 AM
  5. Wake Up,, its time to get back at it!!!,, we HAVE enough,next time
    Last Post: 12-28-2009, 07:00 AM
