Results 1 to 10 of 12
Thread: bandsaw alingment
    bandsaw alingment
    Notice the insert -- yes I need a new one. Photo is to show the blade is too far to the front not the horrible insert. I see no way move it back to the center of the insert. The blade is tracking correctly. Any suggestions?
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    4,699
    Try loosening the table mounting bolts and see if you can get enough wiggle out of it that way. If you have a junker blade put that on first just in case the table jumps a little
    Table has been off and on several times -- upon replacement I push and pulled when tightening with no help of the table position... drives me nuts -- it did not look like this out of the box a couple years ago.
    still sings!
    13,451
    What is the make and model of the BS?
    Darren --> 14” Deluxe Woodworking Bandsaw Model: 10-325
    still sings!
    13,451
    Quote Originally Posted by Paul Gallian View Post
    Rikon? If so, see page 11 for blade tracking: http://www.highlandwoodworking.com/l...325_manual.pdf
    The puzzle is not the tracking .. The blade run dead center on the wheel. But is a good 3/4 inch forward in the hole in the table -- so forward that it eats up inserts. So I just use it knowing that things are not right.
    still sings!
    17,474
    paul if it came to you right then something in the way you put your table on is wrong.. first off does the slit for the blade come toward you or away now? the hole maybe off center on the casting also are you sure your thrust bearings and guide rollers are in the right settings?
    5,322
    Paul,
    If the blade is tracking on the center of the tires, I don't see where you've got a problem. Just put in a new insert, and be happy with the saw.
    The hole for the insert might be machined a bit off center, but I doubt it. My 30+ year old 14" saw does the same thing - the blade is about ¼" forward of center in the insert. I never really noticed it until now, when I looked at it after reading your post, and seeing your picture. The saw works just fine - tracks well, cuts well, runs quietly - so I don't see a problem.
    If yours is tracking well, and cutting well, just make a new insert, but don't cut the blade slot all the way back, and use the saw. No problem!
    Thanks Jim -- that is what will do.. it is just a puzzle for me.
    Paul
    still sings!
  1. Bandsaw Box
    By Bob Gibson in forum Flatwork Project Showcase
    Last Post: 03-25-2014, 07:52 PM
  2. Blade alingment on a Table saw.
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 10-08-2011, 10:39 PM
  3. Bandsaw
    By Dennis Kranz in forum Turning Tool Questions and Show & Tell
    Last Post: 01-11-2010, 04:29 AM
  4. Bandsaw
    Last Post: 07-05-2009, 03:45 AM
  5. BIG bandsaw
    By Dale Johnson in forum Old Iron
    Last Post: 05-17-2009, 03:28 PM
