Results 1 to 4 of 4
Thread: Delta Bandsaw (28-100) parts...Where can I get them?
    I was given and Delta/Rockwell bandsaw by a friend of mine. I need to replace a few parts, but I am having a hard time finding them. The model number is 28-100. The parts that I need are 2 blade support bearings. The part number for the bearings is 426-01-380-0002.
    Any help or suggestions would be greatly appreciated.
    __________________
    Mike
    Tokiwadai, Japan
    2,882
    Mike, Welcome to the forum...
    Here's a parts diagram from "Mike's Tools".
    http://www.mikestools.com/download/D...-Saw-BS-1A.pdf
    He says he has parts....
    http://www.mikestools.com/Delta-Band...ists_2277.aspx
    Might be a source if you can't get directly from Delta.
    The Heart of Dixie
    4,268
    Delta has a lot available as these machines have not changed much over the years. That model number means nothing to me, just to many Delta numbers to remember. But if it you are talking a ball bearing/roller bearing. Just get some dimension on the bearing and go online to an industrial supplier such as Motion Industries. Heck, even a lot of the imported saws parts will fit the old Deltas. After all they are direct copies.
    If I totally missed the mark, post some photos. I am sure we can find a source.
    Jeff
    EDIT
    Ignore my import comment. I assumed we were talking 14" bandsaw.
    Custom built boats and Kits
    The Heart of Dixie
    4,268
    Just thought of something, if you can't find them you might want to join up over at www.owwm.org (Old Wood Working Machines) and ask over there. I bet someone knows where. They may even know the modern bearing numbers.
  1. Old delta parts
    By Darren Wright in forum Old Iron
    Last Post: 12-08-2011, 03:25 AM
  2. Bandsaw Parts Supplier
    By Peter Rideout in forum Old Iron
    Last Post: 02-07-2011, 07:12 PM
  3. Delta Homecraft Jointer parts
    By Matt Ducar in forum Old Iron
    Last Post: 09-02-2010, 11:43 AM
  4. Delta bandsaw Tension
    By Larry Fredric in forum General Woodworking Q&A
    Last Post: 02-15-2010, 12:01 AM
  5. Delta Bandsaw
    By Bill Antonacchio in forum Hot Deals
    Last Post: 01-13-2007, 12:47 AM
