Results 1 to 9 of 9
Thread: Mobile base question
    Los Angeles, CA
    2,668
    Some time ago I bought a shopfox mobile base (G7315z) for my bandsaw. Well, I finally decided to assemble it. I noticed that all the rails only had one hole. My grizzly tablesaw is also on a mobile base and on that base there are two threaded holes on the top on each side of the rails and the bolts go thru the holes on the corner bracket and the holes on the rails.
    I took some pictures and emailed Grizzly's support. Their response was that the bolts just go thru the corner bracket holes and apply pressure on the rails. The one hole on the rails is for shopfox to hang them with and apply spray paint.
    Is this setup going to be secure enough while moving the machine on the base?
ID:	71919Click image for larger version.
    Nov 2012
    Wapakoneta, OH
    610
    I don't know if it's enough....but if it were me, I drill through holes and make sure it stays together.
    3,134
    I purchased a heavy duty Shopfox base made for planers the wheels didn't have any bearings just bolts through the wheels they wouldn't roll or castor at all on nice flat concrete. $60 later & a little steel glue to extend the mounting brackets because the wheels I got were bigger & this is what I had. It now rolls just fine even up over 1/2" interlocking 2'x2' rubber mats. I don't honestly know if I'd ever even buy a Shopfox base again.
    Attached Thumbnails Attached Thumbnails planer 003.jpg   Replacement  wheels for a Shopfox tool base.jpg
    Los Angeles, CA
    2,668
    Bart, did you drill the holes in the rails yourself?
    Feb 2012
    2,746
    I built a mobile base for my bandsaw, and put wheels on the back legs of the tablesaw stand. I found the most important thing was to get sufficiently large to roll over unevenness in the floor. The wheels on my bandsaw are 2" as my experience with the wheels on the tablesaw was that 1" was small enough to hang up on extendion cords and other small obstacles. The 2" wheels roll over most things.
    Cheers,
    Roger
    3,134
    Quote Originally Posted by Mohammad Madha View Post
    No they were already there as I remember. I wish it was that simple to get the base to do what it was meant to do.
    Mar 2010
    Decatur, Alabama
    518
    It depends on which base you buy. I think the heavy duty one comes with through bolts. I have one of each with no problems yet. I don't think you'll have issues with a 14" bandsaw. If it was going to be a table saw, I think I'd want them locked in with through bolts.
    Edit: I have a grizzly 1.5hp shaper on the light base and no problems.
    Los Angeles, CA
    2,668
    Jeb, I have a 19" bandsaw.
    The mobile base is this one:
    http://www.grizzly.com/products/Supe...le-Base/G7315Z
    30,008
    I'm pretty certain that's the same base I've got under my bandsaw. No trouble with it for me, although I agree the way the rails are held in place sure seems questionable.
  1. Mobile base on a TS?
    Last Post: 07-07-2011, 12:38 AM
  2. mobile base for the new bandsaw
    Last Post: 11-24-2009, 10:01 PM
  3. Delta mobile base
    By Rick Levine in forum Hot Deals
    Last Post: 09-23-2007, 04:12 PM
  4. Mobile base for table saw
    By Dennis Thompson in forum General Woodworking Q&A
    Last Post: 06-13-2007, 01:06 AM
  5. FS: Delta 50-296 mobile base
    By Doug Shepard in forum Old Ads
    Last Post: 04-26-2007, 12:56 AM
