Results 1 to 10 of 10
Thread: Shape N Hollow Tool
    Jun 2012
    Laurinburg NC
    319
    Shape N Hollow Tool
    Has anyone used or seen one of these?
    http://www.shapenhollow.com/videos%20snh.htm
    Hadn't seen it before...looks interesting, although I'd still want other capabilities like a swan neck bar and various other cutters and scraper bits. It'd work fine for a trumpet-shaped vase like he's doing in the video, but I don't think it'd get everywhere I'd need to do something like this:
Name:	VM 1030 01 - 800.jpg
    Feb 2011
    Salem, OR
    267
    A good idea, but I didn't see how it would stop the hollowing bar from twisting.
    "Have no fear of perfection--you'll never reach it."
    ---Salvador Dali
    Jim brings up a good point. Without some way to keep the from rotating, it's essentially an Oland tool on a restrained rest. Using any off-center cutting bits would be similar to hollowing freehand. That might explain why they don't offer swan neck bars or angled cutters.
    Goodland, Kansas
    4,834
    For the price and more versitility I would rather have the monster captured or articulating arm.
    Bernie W.
    Palm Springs, Ca
    1,169
    I agree I think my Monster offers more versitility
    Im sure its a nice tool and works but i can do the same thing he did in the video with my indexing tool free hand - I think I bought it from Monster also
    Hi, I am the owner/designer of the ShapeNHollow tool system. I would like to offer some information on my system and its uses.
    I am a very small start-up company and just can’t at this time offer all the bells and whistles that I would like, like a swan neck bar and various other cutters and scraper bits. These are available from others and if they work with a 3/4” or a 1” bar they will work with my tool.
    Turners that have a swan neck tool that has a 3/4” bar can use it with my system. The only thing that I am aware of is that the cutting tip MUST be in-line with the tool bar NOT out to the side. I am not set up to prevent twisting/tool rotation but with the cutting tip in the proper position the swan neck tool will work like a straight cutting tool.
    I will be posting an article in the next week with some pictures on my website showing my latest hollow form project and the tools I used.
    A couple of things I was trying to accomplish with my tool are ease of use/flexibility and using the same tool system for deep hollowing and spindle type work.
    For example, when you want to do a hollow form you can’t always just mount the piece on a faceplate and go. I usually put it between centers and get the grain or natural edge in a position to make it aesthetically pleasing, turn it to the desired shape, cut a tenon, and then mount it in a chuck. After you have the desired shape you can reposition the tool and hollow your project.
    Spindle examples: When removing waste on the outside of any type vessel where you would be using a roughing gouge, or when you are doing off set turning, this system will be safer and demand a whole lot less effort.
    Another example: There are tool rests with several holes drilled along the top to insert a pin to use as a fulcrum. The ShapeNHollow system can do the same thing, and my reasoning for doing this was to reduce the physical effort when you are just removing waste.
    Whether you are working on an extremely out of round project or hollowing a closed vessel, at the end of the day you are not nearly as physically tired as you would be using just hand held tools.
    Thank you for your interest in my tool system. If you want more information, please feel free to contact me. I am planning to post some short videos showing more set-up and tool positioning by the first of the year. My email is on my website.
    Hi Pete, and welcome aboard. Thanks for the insight on your tool. It looks very well made, and you've definitely brought some innovation to the game. Best of success in your marketing endeavors.
    Oct 2011
    Cortland NY
    238
    I can see great potential in this for someone who has aged to the point they can no longer hold tolling like they once could. Also for anyone handcaped it gives the "second hand" or maybe just better control for a tool. Although it may have some weeknesses it sure does have some positives. I'm not a turner (well not yet) but I can see the potential in this.
    Also Pete welcome aboard.
    Yorktown, Virginia
    5,022
    Welcome, Pete and thanks for the info. If you can add some anti-twist capability to your system you'll get a lot more interest.
  1. How to cut the half circe shape?
    By Bob Beasley in forum General Woodworking Q&A
    Last Post: 02-11-2016, 01:21 AM
  2. What tool to use to hollow potpourri bowl
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 10-21-2010, 01:48 PM
  3. New HF Shape
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 12-12-2008, 05:02 PM
  4. Thompson V shape bowl gouge or U shape
    By Keith Palmer in forum Turning Tool Questions and Show & Tell
    Last Post: 11-11-2008, 05:12 PM
