Results 1 to 10 of 14
Thread: Recommended lathe height
    12,258
    My lathe bench has undergone modification.
    To be clear this is a steel bench i have schlepped from pilar to post and across the oceans. It has history that goes way back with me. So parting with this piece of steel is not on the cards.
    Anyhow I have cut about 1/3 of it off its width and merely forced to sides together and used 16 bolts to tie to halves together. Yeah not the neatest job the quickest job at this stage of the year given temps and power availability. Worked out fine.
    Next i used some of the useless for anything else Pine that i lugged from SA as blocks underneath to mount some good LV blue poly casters with brakes.
    So net result is lathe bench is now narrower and mobile.
    Now the result has increased the surface height and before i get to re mount the now rusted lathe bed and get the whole thing back in shape, i wanted to check on what the correct height to work at is and sort that out at the same time.
    I realise this is a little like "How long is a piece of string" but can anyone give me pointers onwhere to start for suitable height and i can then check on comfort and take it from there. I know how i had it previously was way too low for me. But my casters and double mounting blocks have raised it quiet a bit. Before i mount the lathe bed i would like to either lower again or make provisions for a nice mounting block for the lathe.
    I am actually hoping that i can add a decent mounting block to the lathe and still be at correct height.
    Thanks for help and suggestions.
    Feb 2011
    Salem, OR
    267
    I believe that the center of the spindle should be level with your elbow, but it's still a personal choice of where it is comfortable.
    "Have no fear of perfection--you'll never reach it."
    ---Salvador Dali
    Jul 2007
    DSM, IA
    5,719
    Jim's correct...elbow height is the standard, but that is to low for me. Mines probably 3-4" higher, I've never bothered to measure as it was done by what felt right.
    My Website
    Toronto, Canada
    276
    I've had mine as low as elbow, and as high as nipple. I prefer it on the high side, and so does my turning buddy.
    12,258
    Thanks guys i will follow your guidance and then raise it from there.
    new york city burbs
    10,188
    whats going on here?
    are you actually going to use one of those machines?
    ya just joking around with us?
    next thing ya know someones going to tell me someone else just finished a table.
    Human Test Dummy
    11,833
    I'm only 5'7". My first lathe was too low for me so I put 4" blocks under the legs. Then it was good.
    My current lathe is 46" to center and it is just fine for me.
    I prefer to stand upright when working, bending and hunching over is killer on the back.
    30,017
    I'll echo the other guys. Spindle at elbow height is the most common guideline, but I prefer mine a bit higher. How big of "bit"? I dunno...maybe a couple of inches. My lathe's not handy for measuring right now.
    May 2009
    sydney australia
    149
    Yep I 'm in the higher group. I 'm 5.9 so its sits around 48"
    Goodland, Kansas
    4,834
    I made mine 3" higher than my elbow height. Saves a lot of bending over the lathe.
    Bernie W.
  1. Lathe Height
    By Steve Southwood in forum Turning Tool Questions and Show & Tell
    Last Post: 07-21-2011, 12:25 AM
  2. Recommended Table Top Finish
    By Darren Wright in forum Finishing School
    Last Post: 06-03-2011, 03:24 PM
  3. Lathe height and clean up
    By Royall Clark in forum General Woodturning Q&A
    Last Post: 04-01-2009, 02:25 AM
  4. Lathe height?
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 08-29-2008, 02:55 PM
  5. Lathe cabinet height
    By Darren Wright in forum General Woodturning Q&A
    Last Post: 04-06-2008, 08:19 PM
