Results 1 to 10 of 10
Thread: trettle lathe
    Nov 2012
    Alto Mi
    29
    trettle lathe
    here is a trettle lathe i madeClick image for larger version.
    Kevin Hough
    <Lathe work always turns out>
    4,699
    Nice job!
    Can you post a picture from the treadle side? Pretty sure I know how you have that put together, but curious to see anyway
    Do you have an wracking of of the ways without any diagonal support?
    I'm guessing for a long piece you'd need two people, one to treadle and the other to turn
    Nov 2012
    Alto Mi
    29
    no racking and yes on long pieces i need the wife to power it
    Kevin Hough
    Los Angeles, CA
    2,668
    Very Cool!
    4,699
    Quote Originally Posted by Kevin Hough View Post
    Thanks, one of these is on my long list someday.. eventually..
    Mar 2012
    SW Minnesota
    159
    Cool!! A treadle lathe is always my next project. Something always get pushed higher on the priority list. I have a treadle mechanism from a Singer sewing machine that I hope to utilize; but the output would work best if I were a left handed turner. Some day, I will work out the details.
    Oct 2011
    Cortland NY
    238
    Dennis, I have been working on one my self for a few years on and off. I have the bed made as well as the head stocks and tool rest. As it's light weight I built it out of ply. The drive is being driven off of the wheel to a shaft that runs below the bed. It is housed in two pillow bearings. It then drives out past the head stock to drive the live end. It works to that point. I am stumped as to how to drive the stock. I have looked at many ideas but none have been implemented. And there I stand. It is fairly light weight but it will spin the live end real fast. It is something I would like to get finished.
    Kevin, thanks for joining and pictures of your lathe you built. Like the design along the rails and legs.
    Mar 2012
    SW Minnesota
    159
    Quote Originally Posted by ed sautter View Post
    That is what I had figured to move to the power to the proper end, I haven't decided if I would add a second flywheel. The one for the sewing machine may be a bit light for a lathe. I have a 1912 Singer Sewing Machine in the shop and an 1880's New Rogers treadle scroll saw that still needs a bit of work to be fully functional.
    I'm really getting into this hand and foot powered stuff.
    Nov 2012
    Alto Mi
    29
    the small pulley slipped on the drive rope when i first started but i soon learned a little contact spray on the rope (belt) made all the difference.
    Kevin Hough
    Oct 2011
    Cortland NY
    238
    Kevin also an idler wheel would help as well. That would give tension to the the rope so it wouldn't slip.
  1. Replies: 14
    Last Post: 01-14-2014, 03:57 PM
  2. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  3. Grizzly lathe G0698 discontinued vs New Grizzly lathe G0733 Both 18"x 47"
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 12-29-2011, 03:23 AM
  4. first lathe on the way
    By Mark Kosmowski in forum Turning Tool Questions and Show & Tell
    Last Post: 10-01-2007, 01:28 AM
  5. Lathe on the bay
    By Jeff Bower in forum Hot Deals
    Last Post: 08-13-2007, 03:40 PM
