John Daugherty
- Oliver Springs, TN
excellent work Stu, you're progressing nicely.
Looks like your making progress Stu.
BTW....do I see "bunny rabbit" sawhorses in the first photo???
Tom I think that is some kind of barricade at the supply store where Stu got the materials.
Looking Good Mr Ablett!
Say... this is stirring a memory. Didn't you close in another parking spot about 5+ years ago on the street level of your apartment building? I forget, wasn't it for a daycare or some other small business?
It is up on my site >> HERE << but I'm not sure it is here on Familywoodworking, I think it predates this place....?
Yeah, that was it! Then I poke around and find the "in the beginning" page, and it's stunning to see your dungeon empty... If only you had known then what you know now and put down a floor, eh?
Anyway, have fun cutting tile today.![]()
Very nice work. A lot neater than anything I could do. Are the hinges tamper proof, since they are outside the room?
Hey, Stu...
As I look at the last two photos, I'm just wondering about how much storage you're actually getting there. I figure I must be misunderstanding something.
So let me see if I get this or not!
On the south end, that is the hatch to the Dungeon Annex. It is almost never opened, but it does open, right? So you can't really store stuff on top of it, can you? (Actually I think you used to park your bike/trailer there, right?)
On the North end is the metal hatch to the Dungeon itself, which you use to go in and out of your shop. On the left of that is the door into the storeroom, and on the right is doors that cover a mechanical/electrical access of some kind? So I see a lot of traffic areas that need to be accessible.
So just how much actual storage space are you gaining here?![]()
Just following what the makers of the siding recommend, they say that the wall should have this building wrap on it before I install the siding, so I put building wrap on.
The inside has been insulated with fibreglass bats, then I put up some plywood and on top of that I'll put some drywall. The plywood under the drywall makes the drywall a lot tougher, and if I want to put something on the wall, I'm not hunting for a stud. the addition of the plywood cost me about $50, so why not? I don't like the holes you see in the walls of storage areas because it's just drywall, the plywood backing the drywall will make it a fairly tough wall.
Yeah, I agree, but they were quite adamant about using it, and it only cost another $30 or so, so why not?I understand about what you are doing and why Stu I just don't understand the point of the wrap on an inside structure. Really there isn't much point for an under cover storage unit.
