The nails... the freaking nails....
I was told that you need one nail into each stud, there are 14 studs on the long wall and 5 on the short wall. There are basically 5 panels from floor to ceiling, basic math then was 19 x 5 I rounded up to 20 x 5 = 100 nails. I did not forget the corner or the little piece over the door way, or the piece over at the top of the short wall behind the micro van, so lets say 150 nails. Now they sell the nails in two ways, one box of 3000 or in bundles of 50. I wanted to make sure I had enough, so I bought four bundles of 50 for 200 nails, I have one section of panels to do, and I'm out of nails....
I checked, I put all four bundles into my pouch when I started nailing, so the only thing I can figure is that these bundles of 50 nails were more like 25.
I'm going to count every nail and see, but the real drag is that to go and get the nails at the far DIY place, the close one does not have them, will cost me about as much as the box of 3000 in tolls and gas
This is an example of me being penny wise and pound stupid, it is a trap I fall into because I get so much static all the time at how much things cost, so I try to come in a close to what I actually need and not over estimate too much, sometimes this just costs more money. I really should learn by now.
Another example;
The siding, it is 303cm which is just a little under 10' long, you have to transport this stuff flat, it is brittle and will break in the middle if not supported. It is also heavy at 24kg/53lbs for each section. It would not fit into my little van. I could rent a long truck for about $100, maybe $120 with gas etc and just go get the siding, I could have also picked up the drywall at the same time as the large truck has the carrying capacity, but I thought I'd save that $120 by getting the DIY shop to cut the panels so they would fit into my micro van. Well this was a big mistake, the guy at the DIY shop did not want to cut the panels, but I said I was screwed if he didn't so he finally did. To add insult to injury, they charged $5 a cut and I had 16 cuts to do. The guy took forever to cut the panels, there was much dust and SMOKE
and I thought "what the heck is he doing...?" I checked the pieces for length and they were fine, so I loaded up my van and came home. When I went to install them, I find that they are not cut square
Most are off by about 1/4" over the 18" of width. I cannot remove the panels without breaking them, and I know that the DIY place will not take any responsibility for this, so I'm stuck with it looking like a dog's breakfast.
Here you can see the two cuts, the bottom one the guy at the DIY shop did, the top one I did with my Festool saw and a special siding blade that cost about $30. The DIY shop guy had a special saw and blade, but it is very obvious that the blade was very dull.
The long and short of it is that I should have spent the money to rent the truck and then I would have been in control of everything, by letting the guy at the DIY shop do the cuts, I'm now at the point where I can gear up for a fight, or I can just suck it up and try to learn. I think I'll just suck it up and learn, but I hope I do learn, cause this really sucks.
I got the parking bumpers installed, they will stop me from hitting the wall parking the van, they give me about 2" of clearance from the bumper to the wall, not much, but enough.
A small exhaust fan will go here.
Two things I've used on this job that make life a lot nicer....
These are
McGuire-Nicolas knee pads 343, they are great as they are lightweight, but they do have the hard shell on the kneecap area, this saves your knee if you happen to kneel on a nail or screw, and they are not real expensive. Sure make working this kind of job a lot easier.
These ear muffs are great, I can listen to music, or podcasts, and have hearing around me of people talking and when I make a loud noise, they save my ears, love these things!
Well, I'm off tomorrow AM first thing to get them freaking nails, and the extra plywood and drywall I need, I don't think I'll be done by Sunday, but who knows, wish me luck!
