Results 1 to 10 of 19
Thread: A project from Cherry
    Mar 2012
    SW Minnesota
    159
    I traded a Diston D8 to a friend in exchange for some Cherry boards. I've never worked with Cherry, so I decided to build another small chest.
    The first day was stock prep.
    Attached Thumbnails Attached Thumbnails image-3639984379.jpg   image-2583744656.jpg   image-490270696.jpg
    Mar 2012
    SW Minnesota
    159
    The second day was cutting dovetails, dry fitting and cutting grooves for the back and drawer slides.
    Attached Thumbnails Attached Thumbnails image-2174678117.jpg   image-2112521343.jpg   image-31554829.jpg
    17,474
    looks like your using the plywood as a fence to get your grove started is that correct dennis? after you scored it first right?
    Mar 2012
    SW Minnesota
    159
    No, the plywood is just to protect the cherry from the holdfasts. I mark out the sides of the groove and make the first cut on each side with a 1 1/4" chisel. Then I freehand between the lines with the router. I don't do a lot of measuring, the grooves are about 3/8" and the iron in the plane is 1/4", so I make a couple of passes at each depth.
    Jan 2012
    Gonzales, Louisiana
    115
    Very nice, Dennis! Very nice.
    Mar 2012
    SW Minnesota
    159
    After day three, the side drawer supports are installed, and the case is assembled.
    Attached Thumbnails Attached Thumbnails image-1730630676.jpg   image-660124765.jpg   image-1278962953.jpg
    I had many compliments ready to post about your work then I look at your first photo... and saw the door mat. OH NO! anyway -- you sure know what you are doing... hope you know I am teasing about the door mat... Paul
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Mar 2012
    SW Minnesota
    159
    Quote Originally Posted by Paul Gallian View Post
    What better to clean your shoes on?
    Mar 2012
    SW Minnesota
    159
    Now that Christmas is over, I'm back in the shop. The case is done, now to build the drawers.
    Attached Thumbnails Attached Thumbnails image-3929270582.jpg   image-1122245441.jpg   image-2912834893.jpg
    17,474
    looks good dennis,, make sure to use DT's on the drawers as well
  1. High Chair Project
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 10-10-2014, 01:32 PM
  2. Need simple project idea for Boy Scout woodworking merit badge project
    By Jerry Ingraham in forum General Woodworking Q&A
    Last Post: 02-04-2012, 07:52 PM
  3. Cherry
    By peter blair in forum General Woodturning Q&A
    Last Post: 12-20-2011, 12:18 AM
  4. Done! Pics! better a small project than no project at all
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 04-07-2008, 11:28 PM
  5. cherry NE
    By TYLER WOOD in forum Lathe Project Showcase
    Last Post: 11-13-2007, 02:37 PM
