- The Gorge Area, Oregon
Al one other accessory that you may want to line up in preperation for your opening tomorrow is some solvent to remove the goo that the table of machines is usually covered in. Then get some paste wax or boeshield spray and apply it to your table to keep it from rusting and to have it easy to have wood glide across. The boeshield stuff is amazing if you aint used it before give it a try.
Yep the cosmoline can be a bear to get off. I use dilute simply green mostly since its readily available locally... There are undoubtedly things that work better, but its cheap and easy to get.
