Results 1 to 8 of 8
Thread: End Grain Butcher Block For Counters?
    Grand Rapids, MI
    383
    Hey all,
    I have a customer who is interested in having all her new counters made of end grain butcher blocks. She also wants to seal it/finish it with poly cuz she wants the look and will never actually cut on it. My question: Do you think the tangential movement (movement across the flat sawn face) of the wood pieces in this end-grain-up orientation will cause a film finish any problems such as cracking? She is open to having wood strip counters, but would prefer end grain if possible.
    Hutch
    No experience with poly on an end grain cutting board, so I'm not much help there. I do suspect it'd be pretty stable as long as it was sealed on both sides.
    My parents had maple strip countertops in the kitchen when I was growing up, and they just periodically refreshed them with mineral oil. I don't recall any real noticeable movement in those, either.
    NH
    4,006
    I would steer her clear of the polly But the rest of it will be fine.
    Stupid hurts.
    5,533
    I'd steer her towards a traditional mineral oil finish (easily renewable), which would ensure that in case somebody else cuts directly on the counter it would still be safe.
    -Ned
    Grand Rapids, MI
    383
    Hehe, I have a feeling she may not want to fuss with the oil. I found a picture of a large top like this which clearly had a film finish on it. Still, the job could get real fussy real quick. Hm, I have got some pondering to do.
    Thanks guys!
    - Hutch
    new york city burbs
    10,188
    One of the first projects I did, was make an end table, with an end grain butcher block top.
    I remember there was an issue in one of the wood working magazines, that had a coffee table build on its cover, using end grain butcher block for top.
    I rubbed on 2 coats of BLO, then 2 coats of wipe on poly.(Im trying to remember, but I think thats how I finished it) Never had a problem, but its not a countertop used for anything.
    Maybe you can find that article, as Im sure it discusses finishes.
    Human Test Dummy
    Oct 2009
    Dennison, MN
    512
    I'd be curious how well the bar top epoxy would work. Its pretty soft, but its also self healing. So if there was movement, it might adapt well. Just thinking out loud. I did my island top with it, and it turned out okay with the top I made out of Mahogany scraps. (I was too cheap to pony up $800 for a granite island)
    This should be uber stable though. Its mostly MDF core material. Just the outside border is solid.
    "Do, or do not. There is no try."
    -Yoda
    Westphalia, Michigan
    955
    I would think one would want to finish the bottom side of the counter top at least with an oil finish. Some woods will suck in an oil like mineral oil through the capillary tubes but in some the tubes are blocked. IF the bottom was unfinished and water did run down the ends or sides and get on the bottom it might cause some problems. This is just some thoughts with no experience to back it up.
    I'm a certifiable tree hugger. (it's a poor mans way of determining DBH before cutting the tree down)
  1. The butcher block project...
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 04-17-2013, 04:47 PM
  2. WIP-Another Kitchen Island, but with butcher block top.
    Last Post: 09-21-2011, 12:31 PM
  3. how would you flatten an old butcher block?
    Last Post: 02-17-2007, 02:54 PM
  4. Butcher Block Cutting Board Take II
    By Vaughn McMillan in forum Flatwork Project Showcase
    Last Post: 01-03-2007, 02:48 AM
  5. Butcher Block Oil...............
    By Mark Rios in forum Finishing School
    Last Post: 11-16-2006, 10:01 PM
