Results 1 to 10 of 13
Thread: Mortiser/Drum Sander Questions
    Jan 2011
    Hudson Valley NY
    122
    I'm thinking of taking a ride to Grizzly in Muncy Pa. after the holidays. I am thinking of buying a G9976 Mortiser and a G0459P 12" Drum Sander. I was wondering if any of you have either of these and how well they work? Are they worth having in a small shop? The sander really looks like it would save a lot of time and would help get a real flat surface. I have never used either and was wondering if anyone has any experience with them. Thanks.
    Dec 2008
    falcon heights, minnesota
    5,604
    i have the g0645 mortising machine, and it's a real trooper. if you're only doing a hand full of mortises, i'd recommend the one i've got (and you'll save some $$ too). cannot say anything about the sander, but the service people at grizzly are good. i've bought several machines from them.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Jan 2011
    Hudson Valley NY
    122
    Thanks Dan. The g0645 is the one I am considering, I wrote the wrong number down.
    17,470
    drum sander? you need to look at that drum sander as a flat surface sander but its not a finish sander you will still need to sand by hand with a RO or sanding blocks, they work well for figured woods that your planer wont plane smooth without tear out.
    mortiser? like dan mentioned you need to look at how many mortises you plan to make, sometimes just a drill and chisel plus your table saw will suffice..
    to many of us, me included bought this tool or that tool because we thought we needed it then to find out it just collects dust most of the time
    Bellingham
    2,449
    Very true, and I am working toward getting rid of those tools.
    new york city burbs
    10,184
    sayer, I sent you a pm.
    I have a delta mortising attachment for drill press that I havent used in 2 years, and you are more than welcome to it.
    Human Test Dummy
    Jan 2011
    Hudson Valley NY
    122
    Thank you all for the info. I did look into the attachment for the drill press but as I will be using this a lot I think it would be easier to have a dedicated machine. I also have a few of those had to have items that collect dust. Allen, thank you for your generous offer, I sent you a pm. I will need to rethink the sander, I thought it could also be used as a finish sander with the correct grit paper.
    17,470
    with fine paper you can get a decent degree of smoothness but not ready for finish on anything i have ever done with one.. a random orbital is one tool that you will always need unless you get into hand tools heavily and can smooth wood with a plane effectively. let alone it takes time to change out the grits to do a proper sanding job with one of the drum sanders .. in my opinion its tool for getting things close and flat.. and for that the right one is indispensable
    new york city burbs
    10,184
    if youre going to be building table tops or panels for doors, a drum sander is a beautiful tool to obtain a nice even surface.
    go for the biggest one you can afford.
    Human Test Dummy
    Jan 2011
    Hudson Valley NY
    122
    Thanks, I learned that with my planer, bought a 8" and its way to small.
  1. questions about jet 10-20 drum sander
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 09-28-2013, 04:18 PM
  2. Drum Sander.....?
    Last Post: 10-23-2011, 03:40 PM
  3. Drum sander
    By Ed Gerhard in forum New Tools
    Last Post: 09-21-2009, 06:17 PM
  4. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
  5. new drum sander
    By Gene Miller in forum New Tools
    Last Post: 10-13-2007, 06:44 PM
