Results 1 to 10 of 23
Thread: Third hand support
    17,470
    Third hand support
    well we have heard the saying of "necessity is the beginning of inventions" or something along that line. well i ran into a situation where i needed a third hand, and i had called for support but wasnt ready to give up on my idea yet.. so i looked in my scrap pile and grabbed some plywood and cut these out and screwed them together.. i havnt spread the glue yet but i am pretty sure i can do what i need to do easier this way than by doing one side at a time and clamping against the tenon to get them tight and square..i got two more of these to do so i figured the 15mins of cutting these out would be worth it if they worked..
Name:	third hand support 001.jpg
Name:	third hand support 002.jpg
    so how would you go about making this glue up?
    I usually use my parallel wood clamps to support pieces that need to stand up.
    I would cut a couple of pieces of scrap to span the back side of the cabinet to help keep it square and to focus the clamp pressure on the joints.
    13,353
    I made a couple of those in a larger form when I was doing some work on some doors a while ago. Very handy.
    NH
    4,003
    What Allen said. Do the same thing for doors that need hinges let in or need to be planed down.
    Stupid hurts.
    May 2009
    Lafayette, Indiana
    2,379
    Very clever Larry. Well done.
    If you really want to go high tech you could make one side adjustable for different thicknesses of material. The ideas are rolling now in my noggin!
    4,551
    That right there was the BEST solution Larry and you wont be sorry for spending the time on them as you do the rest of those glue ups.
    A Turn N Time
    Frog Pond Guitars
    17,470
    what are you referring to as parallel wood clamps alan? and as for making them adjustable that could be done but at the time i was just looking for the third hand
    Thomasville, GA
    5,989
    He's probably referring to handscrews. That's what I use for those applications. But, a set like you built that is adjustable is the best bet.
    Bill Arnold
    These!
  1. Support the hobby - commercial
    By Leo Voisine in forum Computer-Aided Equipment Project Showcase
    Last Post: 02-06-2014, 11:37 AM
  2. leaf support idea
    Last Post: 05-02-2012, 11:57 PM
  3. dresser support question?
    By larry merlau in forum Designs, Plans and Sketches
    Last Post: 02-13-2012, 02:43 AM
  4. The Very First Call To Tech Support
    Last Post: 06-21-2011, 11:40 PM
