Results 1 to 9 of 9
Thread: Did a little milling today
    Oliver Springs, TN
    1,726
    We cut up a small red oak and another piece of spalted maple today. The red oak was a small one, but we were able to get some nice QS boards.Click image for larger version.
ID:	72964Click image for larger version.
ID:	72965 The maple was nice too. I cut this one thicker, mostly 2 and 3 inch slabs. Here's a couple of pictures and one of a bookmatched pair.Click image for larger version.
ID:	72966Click image for larger version.
ID:	72967Click image for larger version.
ID:	72968 This last picture is of a chunk with some fairly nice figure, it's 36" long.Click image for larger version.
ID:	72969Click image for larger version.
ID:	72970 I probably spend as much time trying to decide on how best to cut a log as on the actually cutting.
    17,470
    Quote Originally Posted by John Daugherty View Post
    http://familywoodworking.org/forums/...8&d=1357427574
    what size are these john?
    and how is it that your oak is so red looking in the pictures?
    Independence, Kentucky
    1,354
    Hey Larry, he did say "We cut up a small red oak"
    17,470
    well charles the red oak i have cut isnt even close to that red that he shows just ask tom he has seen some of it i think he must be feeding his trees red dye
    1,354
    Well, that is some pretty wood that he has there, should make some nice projects I know Red oak isn't usually that red.
    Oliver Springs, TN
    1,726
    Re: Did a little milling today
    Going from memory Larry those are around 15 - 18 inches by 8 ft. Those pics of the oak are right after the cut and are wet from cutting. I use water as a blade lubericant. When they dry they turn the normal red oak color.
    17,470
    how thick?
    Oliver Springs, TN
    1,726
    they are right at 3 inches
    Jan 2011
    3,798
ID:	73010 looks nice
  1. milling a maple
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 12-12-2014, 11:47 AM
  2. Milling an Oak
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 11-18-2014, 02:08 AM
  3. Milling Around
    By Don Orr in forum Lathe Project Showcase
    Last Post: 03-05-2010, 05:08 AM
  4. Vertical MIlling
    By Randy Wynn in forum General Woodworking Q&A
    Last Post: 10-26-2009, 11:11 PM
  5. How much time after milling?
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 07-19-2007, 02:08 PM
