Results 1 to 10 of 23
Thread: Pocket Hole Face Frame question?
    13,361
    When making face frames with a pocket hole jig...
    1. Is there any reason to use glue on the joints in the face frame?
    2. Is there any reason to use glue to attach the face frame to the carcass?
      again, assuming you are using pocket screws to attach the face frame to the carcass?
    new york city burbs
    10,188
    I use the pocket screws so I dont have to leave it clamped over night to work with it.
    I use glue on every pocket screw assembly. what would be a reason not too? (cured glue is stronger than wood)
    Same with attaching it to box.
    Human Test Dummy
    Oliver Springs, TN
    1,726
    ditto what Allen said.
    13,361
    I can see doing the glue on the face frame to carcass, but it just seemed like the since it is mostly butt joints in the face frame, didn't see it adding all that much value.
    Anyway, I've got the face frame and carcass all built up and dry fitted.
    Trying to figure out how far I need to dis-assemble everything now. I was going to prefinish everything, then do the glue ups.
    I always glue mine and at work we always use glue in the joints on face frames along with attaching them to the cabinets.
    The only time we don't use glue on pocket screws is if we feel the installer might need to take something apart that might need to be modified in the field otherwise ALL joints done with pocket screws are glued.
    13,361
    Good to know, So I guess it can't hurt!
    I'll do a full dismantle tomorrow and start working on the sanding and finishing.
    I at least wanted to seal the wood prior to gluing up.
    Just another experiment to see how to deal with glue...
    10,604
    I use a little glue on the butt joints but if I remember right the directions on the Kreg jig says glue is not necessary
    17,472
    brent dont sand to much on the joint area, you can take one side down lower than the other leaving you with a ledge,, i would glue and screw then sand once its together to keep the joint area the same plane.
    Austin, Texas
    1,448
    I do glue my pocket hole joints.
    BUT if you are going to pre-finish, be sure to mask the glue area if you use conventional wood glue. The usual PVA wood glues only work well on porous material (wood, paper, leather, etc.). If I have to glue a prefinished or sealed surface, I switch to epoxy or to the hated polyurethane glue, which do not require a porous surface. Further, if you are gluing a finished surface, the failure of the joint may be between the wood and the finish, not at the glue itself. Bottom line, I assemble before finishing.
    Charlie Plesums, Austin Texas
    13,361
    Thanks for the tips guys.I guess I'm more concerned with prefinishing the carcass since the veneer on it can take a lot of sanding.
    My plan will be
    1) Completely disassemble carcass and face frame.
    2) Sand and finish the carcass, making sure not to get finish in the dados or on the edges
    3) Glue and assemble carcass
    4) Glue and assemble face frame
    5) Sand face frame
    6) glue and assemble face frame to carcass
    7) finish face frame
    I'll be following a simple finishing schedule.
    1) Sand to 220
    2) Apply a coat of seal coat
    3) Knock the nibs off that coat with some synthetic steel wool.
    4) Apply several coats of wipe on poly.
  1. Face frame
    Last Post: 09-23-2014, 07:40 PM
  2. Newby question and pocket hole joinery
    By Leo Wirtz in forum General Woodworking Q&A
    Last Post: 02-07-2011, 06:36 PM
  3. Rockler pocket hole clamp question
    Last Post: 10-05-2010, 12:37 PM
  4. Coarse or fine - pocket hole screw question
    Last Post: 05-28-2009, 03:48 PM
