Results 1 to 4 of 4
Thread: Frameless construction question
    Tampa
    281
    Arrow Frameless construction question
    I have a kitchen cabinet project coming up that calls for frameless cabinets.
    What is the best joining method; pocket hole screws, biscuits, or dowel or a combination of both?
    Floydada, Tx
    1,941
    I just use pocket hole. If it is on a cabinet where the ends dont show screws work good to. Mostly I strat by pocket screwing the bottom to the sides, then add the back then a strip on the top to attach the counter. Then I screw on the base.
    Thomasville, GA
    5,994
    Dadoes or rabbets plus glue and screws where they don't show. Dadoes or rabbets plus biscuits and glue otherwise. I also use pocket screws in areas where they won't be seen on some projects and plan to incorporate them more as I go along.
    Bill Arnold
    May 2011
    Cape Cod, Ma.
    1,553
    #6x2 inch wood screws countersunk with 1/2" plywood backs rabbeted into the sides and stapled every couple inches, screwed top and bottom.
    Also, edgeband the plywood before cutting to final size makes for a much easier time
  1. Frameless Cabinets
    Last Post: 12-31-2011, 03:01 PM
  2. Cabinet Construction Question(s)
    By Mark Kelly in forum General Woodworking Q&A
    Last Post: 09-29-2011, 05:08 PM
  3. construction question-
    By allen levine in forum Carpentry and Construction
    Last Post: 05-14-2010, 01:48 AM
  4. handrail construction question
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 05-11-2010, 02:50 AM
  5. New contender for Dumbest construction question prize for 2007
    By Bill Lantry in forum Carpentry and Construction
    Last Post: 11-23-2007, 01:41 AM
