Results 1 to 3 of 3
Thread: Plumbing problem(s)
    5,533
    Plumbing problem(s)
    Today's honeydo list started out with the bathtub drain not working well. As it turns out we have a 'pop up' plunger drain, which was/is draining slowly. SO I tore into it and EVENTUALLY got the two screws undone.Got the mechanism out, and now I'm searching for a replacement, in case cleaning it up doesn't do the trick.
    and oh, by the way (just love that phrase, really)... The kitchen sink supply lines are leaking too honey. Auuugh!
    *sigh* just a 'thing'. Couldn't have asked me when I had Time on my hands could you honey? LOL
    -Ned
    Hi Ned.
    My experience with tub drains has been with hair clogs around the drain plug works. A good cleaning often fixes the problem. While you are at it, you can do some 'fishing' for the clog with a piece of coat hanger with a hook on the end. Otherwise, you might need to snake out the pipe between the tub and the main sewer line, but first I would try a couple good doses of Drain-o. (Be careful, it contains lye.)
    Oh yes, I have had success running 3 or 4 inches of HOT water in the tub and then using the 'plumber's friend' to loosen the clog in the pipe.
    IM12
    5,533
    well, having removed the stopper, and before I could clean it and reinstall, our youngest's grandmother called. Quick, get the kid in the shower, he has a birthday party to go to! Now I said? NOW! is the reply.... mutter mutter mutter... picking up tools etc...
    the tub drained just fine ! Hmmm, going to do the drano thing though. The shower is what gets used the MOST, so for right now it is still functional without the stopper.
    -Ned
  1. Oh a plumbing I will go.....
    By Drew Watson in forum Off Topic Discussion
    Last Post: 08-04-2010, 02:43 AM
  2. Anyone with a plumbing background - Help please?
    By Chip Charnley in forum Off Topic Discussion
    Last Post: 08-28-2008, 07:18 PM
  3. plumbing question
    By ken werner in forum Off Topic Discussion
    Last Post: 11-05-2007, 02:03 PM
  4. Plumbing help needed
    By Matt Dunlap in forum Carpentry and Construction
    Last Post: 09-17-2007, 11:58 PM
  5. plumbing for air
    By Kevin Brown in forum Carpentry and Construction
    Last Post: 03-31-2007, 02:34 AM
