mike marvel
- So. Florida
A tool used correctly is much more efficient, and produces good results. If one wants to totally demolish a phillips head when driving a screw, there are a few tips I can give from personal experience.
First, make sure your screw bit is well worn. A #1 bit used in a #2 head tears 'em up pretty good. Use the fastest speed your tool has. Second, manage to be off the line of the screw, that is maintain a slight angle to the screw. Third, try to have minimal pressure on the screw bit into the screw head. Fourth, after the screw has seated, leave the bit spinning in the head.
Other tips: Don't bother to take the time to drill any pilot holes. Having the screw split the wood is only a minor setback. Having the screw skip off the starting point will allow your bit to nicely plow into the wood and leave a distinct pattern of the bit. That could add a "design detail" to the woodwork.
Better than that, you could be lucky enough to have the bit skip off the screw and plunge directly into a portion of your hand causing you to bleed all over the work. It can leave a very nice looking pattern deep into the skin. Or, a bit driving into the nail can bring some interesting sounds similar to yelling. Most words at that time start with "F" or "S". Heck or gosh darn aren't usually uttered.
Another tip of the day: If you aren't one to wear eye protection, you'll be thrilled with this next procedure. Don't take the time to drill pilot holes when working above your head. Try to keep the screw on the cool magnetic bit/holder for overhead work, and manage to do it directly above your face. Try to hold several screws in the freehand while doing this so they can also fall onto your face.
For the muscle bound grip of steel craftsmen out there, holding heavy parts or ill fitted parts with one hand and driving screws with the other is a real time saver and proves clamps aren't really necessary.
It's not necessary to take the time to figure out what length screw should be used. Make sure it's a little long so it will poke through the other side giving maximum grip. You probably have a belt sander.
Make sure short screws keeps spinning when fully seated. This assures that they won't go any deeper. Countersinking may be a useless step. Having protruding screw heads are so much easier to find.
For maximum bodily injury, work so that the screw/driver is pointing at your face or body.
These are tips from a been there done that guy that should not be followed.
