Porter Cable Table Saw
Yeah, it's a shame they went to steel extensions. There is a Craftsman version of this saw, costs a little more. Reg. 599.99, 579.99 with C-man Club card, and extra 5% off if charged on Sears card. Gets it down to 550.99, so still a little higher. They sound like they are identical machines except for the color. My vote, from experience with my Ridgid 3612 is the Ridgid unit, though I like my 3612 grey color better.:p You could always get some cast iron extensions to change the steel ones to. Seems Like HF used to have some CI units for not too much money, but a quick search didn't show anything. Ebay has a bunch of the Sears/Ridgid webbed cast iron finger pinchers available. That's what's on my unit. Might be better than stamped steel. Have no idea what it would cost to ship them. Jim.
Thanks to everyone who gave their opinions and ideas for this post. Especially to Vaughn for going above and beyond and out of his way to make trips to Lowe's and HD to inspect the PC and the Ridgid saws to give me his in-depth analysis of both tools. His opinion and knowledge was a huge factor in my final decision to ultimately go with the Ridgid saw. It's too bad I couldn't find a decent saw thru my local Craigslist posts but, in the end, I believe I made the right choice based on the budget limits I set. After I set up the saw and begin to use it, I'll let you all know how I feel about the saw with an in depth review. Thanks again and God bless you all!
Speaking of used, Craigslist looks pretty weak right now. Here's a real gem I found:
http://albuquerque.craigslist.org/tls/3511659529.html
I think that guy is on drugs if he thinks he can get $1000 for that saw.
This one looks OK, but the price is about $300 to $400 too high IMO.
http://albuquerque.craigslist.org/tls/3507786744.html
Them guys out there been getting into the peyote???? Aint neither one of the saw worth any where near what they got on them for a price. And here all this time I was thinking the guys up here where on crack with some of the numbers they come up with. Oh well guess stupid is a nation wide thing.:thumb::rofl::rofl::rofl:
Back on topic, took me a look at that PC tonight yup it's not for me but I am sure someone will have a use for it.:thumb:
That PC saw is just a re-brand of the Hitachi table saw I have.
It's actually not a terribly bad saw but not as good as the Ridgid you guys are talking about.
I still have that Hitachi. I use it as a dedicated dado blade. Its still working. 2012-11-26 09.30.44.jpg
Barney, I had a look at the P-C 270TS at Lowe's, and frankly, I'm not impressed at all. Personally, I wouldn't buy it. It's maybe a $300 saw IMO, and here's why:
  • The action of the hand wheels was not smooth at all. It felt like there were multiple detents as I turned the wheels. I felt resistance and heard a "click-click-click-click" as I turned either of the wheels. Not smooth at all. Also, the front-mounted tilt adjustment has an additional right-angle gearbox in order to do its thing. As I mentioned earlier, the benefit from having that crank on the front isn't big enough to warrant another mechanical thing that can get jammed up with sawdust or break.
  • Based on what I've read on the web, the blade height adjustment gear is plastic. That would be a deal-breaker for me. The whole integrity of the blade position relies on the trunnion being rock solid. I just don't see plastic holding up, and I saw one person posting on Lumberjocks to complain not only about the busted plastic gear, but that he was having trouble getting a replacement from P-C.
  • The throat plate does look to be an odd size and thin, which would potentially make it difficult to find or make a zero-clearance insert for the saw. (A zero-clearance insert is critical, IMO.)
  • The dust collection port is 2 1/2". That'll fit a shop vac, but a shop vac is not a very effective dust collector for a table saw. My preference would be for a 4" port, since that's a more standard size for dust collector hoses. (It's also easier to reduce a 4" port to fit a shop vac than it is to enlarge a 2 1/2" port to fit a dust collector.)
  • The two extension tables are indeed stamped steel. Although workable, they are much harder (if not impossible) to get flat and level with the cast iron core table.
  • The blade tilt indicator on the top of the table is a nice marketing feature, but worthless in the shop, IMO. The scale on the dial is nowhere near fine enough to accurately set an angle. My guess is that it'll get you within a degree or two of what you're wanting, but when I set my blade to 45 degrees, I need it to be exactly 45.0 degrees, not 44.9 or 45.1 degrees. (For that reason, I use other tools to set my blade angle and pay no attention to the indicator on my saw.)
  • The On-Off switch is mounted on the cabinet itself in a position that looks like it would be hard to turn off with a knee or thigh. For me (at 6' 2" tall), I'd have to bend to turn off the saw with my hand. (I like to be able to turn off my saw with my thigh or hip, so I can stop it in an emergency without letting go of the workpiece.)
  • I will say that the fence operated smoothly and the fine adjustment knobs seemed handy, but the fence only locks on the front rail, which means it can flex a bit if you put pressure on the back half of the fence. Also, the miter gauge is decent and comparable to other factory miter gauges I've seen, including the Ridgid. (I don't like any of them...I much prefer the Incra miter gauges.) The miter gauge slot is 3/4", which is a good thing.
So after looking at the P-C, I decided to go to Home Depot to see what I could learn about the latest Ridgid. Like you said, all they have on display is a box and a price tag, but I did learn a few things at the store and on the web afterward:
  • Sadly, the Ridgid also has stamped steel extension tables. I guess that's what had to happen to stay in the same price range.
  • The fence looks comparable to the P-C, although it locks in both the front and back. When locked, I'd expect there to be no flex. It does not have the micro adjust wheels, but IMO those are not critical.
  • The Ridgid has a 4" dust collection port.
  • The On-Off switch mounts on the bottom of the rail where it can be hit with a hip or thigh if necessary. Its position can be slid anywhere along the rail, so it can be positioned where it works best for you.
  • I can't tell what size or thickness the throat plate is, but if Ridgid followed their past actions, buying or making a zero-clearance insert should be relatively easy.
  • Both saws are belt-driven, run on 120v or 240v, and have built-in mobile bases.
If I had to choose between the two, I'd go with the Ridgid in a heartbeat. The money saved could be applied to a good thin kerf blade. (The factory blade is probably pretty decent, but most of us have different blades for different cuts.) I still prefer my older TS3650, though, primarily because it has cast iron extensions. (The new one has better dust collection, though.) I know I sound like a Ridgid fanboy, but Charlie is right about them being pretty much the gold standard in this market segment.
Keep in mind these are just my own opinions...whether you buy new, used, gray, orange, or rusty, you should get whichever saw you think will work best for your needs and budget. :)
Most of this description sounds just like my Delta TS.... it's very light weight and while it will do most of what I do, I question it's accuracy, it's sometimes a little cumbersome to set up, I've actually lugged the motor with some heavier pieces, the switch is mounted on the left side of the cabinet under the table, with the bulk of the switch inside the cabinet where it gets filled with saw dust and every couple of months I have to take it apart and clean it.... I don't have a dust port, but mounted a wide mouth below the saw to try and catch as much as I can... generally speaking, had I known better, I don't think I would have bought the Delta... the Porter Cable is likely a re-named Delta. Just my humble and uninformed opinion.
