Results 1 to 10 of 13
Thread: little marquetry
    Apr 2009
    Outside the beltway
    5,250
    little marquetry
    Doing a little marquetry the last few days. Made a door of birds eye to match the back board of a small cabinet and needed to match up to.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    13,437
    4,698
    SE Minnesota
    2,524
    Cool!
    17,470
    dont stop there dave your just gettin started
    Apr 2009
    Outside the beltway
    5,250
    I've used 2 different transfer methods. After drawing out the design I used Transfer paper for one but then decided to use think blue type for the other. After I chiseled out the design I layed the type over the cuts and edged it with a knife. Then put the type on the Mahogany veneer and cut the design out. This was very easy and much more precise then using the transfer paper.
    17,470
    you sure do get a large variety of work over there,, sure shows where the money and those that want to spend it are.. let alone the amount of old furniture worth restoring.. well done dave.. your still rubbing off on me i got another fix it job last night a drop leaf table with no top and part of one drop leaf missing but the legs and aprons are there they want it repaired.. but wont be for the numbers you get.. but its work
    Apr 2009
    Outside the beltway
    5,250
    Well the good thing is Larry , your starting to get work.
    The piece of birds eye I used came from an old drawer bottom. So it's about the same age.
    Apr 2009
    Outside the beltway
    5,250
    Just finished this up.
ID:	73480Click image for larger version.
    SE Minnesota
    2,524
    Beautiful work.
  1. Who does Marquetry
    By Roy Millsaps in forum General Woodworking Q&A
    Last Post: 08-12-2014, 03:22 AM
  2. Some Marquetry
    By Mike Henderson in forum Flatwork Project Showcase
    Last Post: 06-13-2012, 04:51 PM
  3. Marquetry Course with Paul Schurch
    Last Post: 11-14-2011, 04:00 AM
  4. Second Marquetry Panel
    Last Post: 10-19-2011, 05:59 AM
  5. First Marquetry Project
    Last Post: 09-27-2011, 09:09 PM
