Results 1 to 10 of 17
Thread: Table fix in future?
    17,472
    well here is what i got handed to me and now i need a part, the slide support is missing on the one side, any ideas where to get another? also i can either put it all back together or make the pieces and let the home owner do it,, its gonna get painted again.. so dave whats your take on this its a older drop leaf table that used to slide apart but the mechanism for that is gone and they dont want it to do it again,, happy to just have it scabbed on the back of the aprons.. these folks like the shabby type decor ..
Name:	table fix pics 001.jpg
ID:	73145 this is the hardware piece i need, it appears to be cast. any ideas where i can get one?
Name:	table fix pics 005.jpg
ID:	73144 Click image for larger version.
Name:	table fix pics 002.jpg
ID:	73146 the old style of pocket holes and some glue blocks for bracing
Name:	table fix pics 003.jpg
ID:	73147 Click image for larger version.
Name:	table fix pics 004.jpg
ID:	73148 tenons loose and boards missing and need to be profiled..
    so would do it all or let them have at it for part of it?
    13,442
    Looks similar, could use part of it and the existing hardware for the bracket: http://www.architecturals.net/drop-leaf-support-iron/
    Some that look like the original..2 in stock: http://www.b-c-e.biz/products.asp?wh...ure+hardware+#
    5,320
    Looks like Darren has solved your hardware problem.
    You're making a new top, right?
    I think I'd make new front & rear apron pieces, rather than try to join (and re-attach) the old ones.
    Who's doing the painting - you, or the client? Stripping and sanding that ols finish won't be fun. Watch out for lead-based paint, too!
    Will you be doing anything with those old rusty casters?
    17,472
    well jim, this client is gonna do the painting, and as for the casters could use one more,, you sound like you were interested in them as for the new top i am just gonna add wood where its missing this lady likes old beat up furniture.. paints it and uses it or sells it to another. if it were mine i would get the slide mechanism and make it work like it used to..but they dont want the leaves just a narrow closed type table. as for the lead i know about that been threw the course
    5,320
    I kinda like repairing/reclaiming old stuff like this. It's kinda fun to bring it back from the dead, so to speak. That one looks like it might be more work than it's worth, though.
    17,472
    so far its just a few boards and hardware i am not gonna get to into it because the paycheck wont be there i dont think.. as for the table profile i can get close with one bit i dont have, looked at it as doing it in two passes, will get a close up of the profile later but any ideas on how to match it is real similar in shape to a whiteside bit number 3228..
    17,472
    well its done and ready for the paint and a sander afterwards to make it look older they didnt want anything glued together on the top wanted it to look wore out..so we laid out the top and used a slat underneath to hold the top together, then figured out the ellipse for the pieces that needed to be replaced and cut to size, then took a bowl bit to make one cut and a cove and bead to make the rest of it then had to form it from there with a rasp and sanding. came out pretty close and the hardware darren linked me to worked just fine for the missing support. so another project is out the door and on the the next one
Name:	french table 003.jpg
ID:	73508Click image for larger version.
Name:	french table 001.jpg
ID:	73509Click image for larger version.
Name:	french table 002.jpg
    NH
    4,005
    Stupid hurts.
    5,320
    Looks good! Did you buy new drop leaf hardware, or 'improvise?'
    10,604
    Nice job Larry
  1. A TS in my future
    By Al Launier in forum General Woodworking Q&A
    Last Post: 02-17-2013, 01:30 PM
  2. The Future is Now.....
    Last Post: 05-07-2011, 07:57 PM
  3. New table saw and Bandsaw in the near future...
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 04-19-2011, 07:09 PM
  4. Future Car
    By Pete Simmons in forum Off Topic Discussion
    Last Post: 03-01-2008, 03:30 AM
  5. The Future of Woodworking?
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 12-21-2007, 04:10 PM
