Results 1 to 8 of 8
Thread: Spray adhesive?
    Tampa
    281
    Spray adhesive?
    How do you guys apply veneer and laminate adhesive?
    What kind do you prefer?
    Floydada, Tx
    1,941
    I use spray on contact cement in a 20# tank Works real good for laminate. For venner I use plastic resin ( Dap Weldwood) comes in a powder for nd you mix the amount you need.
    Tampa
    281
    Can you elaborate on the resin for veneers?
    17,470
    its some times called plastic resin glue julio.. it looks like chocolate pudding when mixed..
    link to info on it julio...LINK
    Austin, Texas
    1,448
    For laminate, the answer is contact cement applied to both sides, dry to tacky, then press together. No tolerance for misalignment so the trick is alignment. I have rolled and brushed it, but not sprayed it, although I have heard of people who sprayed. Everyone I know who has used the solvent based has had good luck; the results on the water base are mixed.
    For veneer, I use the plastic resin glue Larry pointed to, or the equivalent. Big debate whether it should be applied with a notched trowel or a hard rubber roller (I use the roller now). I don't know anyone who sprays it. It is applied ONLY to the substrate, not to the veneer.
    Charlie Plesums, Austin Texas
    2,784
    Charlie has it right in my book. Although I use a roller for the Weldwood on my high pressure laminate. The only time I have seen it sprayed is when gluing a fabric to a hard surface. Like Ozite to wood for automotive woofer boxes, or headliner material or vinyl, also in automotive applications. With the fabric, you don't want to saturate it with the glue. Spraying keeps it light but still allows it to adhere. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    17,470
    i have sprayed water base adhesive for kitchen counters and had it work fine in missouri but up here inmy own shop i use the brush on or trowel type trowel out then make sure its coated both sides like charlie says.. use slip sticks to aid in postioning. old window shades work well for that. then go over it with a roller to make sure you have no air pockets.
    Quote Originally Posted by Julio Navarro View Post
    This stuff http://www.dap.com/product_details.aspx?product_id=42
  1. Recommended Spray Adhesive?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2015, 05:06 AM
  2. Laminate adhesive
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 03-11-2013, 06:32 PM
  3. Proper adhesive
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 01-18-2013, 05:25 AM
  4. Self adhesive rule that came with my table saw....
    By Craig Johnson in forum New Tools
    Last Post: 03-29-2009, 08:15 PM
  5. Spray on Adhesive that lets go when done...?
    Last Post: 02-22-2007, 11:48 AM
