Results 1 to 10 of 18
Thread: miter saw angle for outside corner molding?
    Hi,
    I need help figuring out the correct angle to cut outside corner molding when installing it around a hall entrance. The corner molding is 90 degrees (to cover up where the wall corner meets, looks like this: http://mouldinginstallation.com/how-...molding-0-jpg/), and I'd like to do one side, and the top of the hall entry. Flawed thinking...cutting at a 45 degree angle, like when making window frames, does not work. I do not think this would be a compound cut, but the angle has me perplexed, being two-sided.
    Thanks for suggestions.
    -Patti
    17,475
    if i understand you correctly you are trimming out a alcove in the entry way so you would cut a normal 45 just need to position the trim in respect to where its going patti,, take a small piece and try it till you can see the picture your after.. oh and welcome to our forum, we are a united group of some great talent
    A 45 degree cut would work fine, if you lay the trim flat. But, covering 2 walls with the 90 degree corner trim throws off the angle.
    4,701
    Well its 1/2 the angle of the corner... whatever that is. I believe, based on the description, what you're finding is that the corner is not in fact 90 degrees but some ~not quite but almost 90 degree angle. This is fairly common when doing trim work (at least it was in my house ) so you have to figure the angle and then bisect it.
    Doing one side at 45 and then matching the other will "work" but tends to leave the side with the longer angle proud a little (ok if its paint grade, just bevel it, caulk it, paint it and call it a day), not so happy if its stain grade.
    The easiest way is to use something like this: http://www.leevalley.com/US/wood/pag...37&cat=1,43513
    Worth the $20 if you're doing a lot of trim and aren't really good at eyeballing it/fitting to match.
    More generally useful is something like this (there a myriad of variations, this is not what I have, I have something almost but not quite the same I picked up at an estate sale for $1): http://www.amazon.com/Starrett-505P-...dp/B003CJSQ4S/
    Where you can measure the outside angle and then divide it in half to get the correct angle
    Round corners are more interesting, I had a lot of those when I redid the trim in my current house. They look best (to me) with 2 small blocks between the long trim pieces to compound the curve. The angle to cut is the all angle divided by the number of cut sides so in this case we have the 2 long trim pieces and 2 short trim pieces to go around the corner so its "90" divided by 6 (=====s1 2s3 4s5 6s=====) or 15 degrees. I cut a whole little box of the short pieces (about 1/4" wide at the back/narrow part) and just fit them as the went in place on each corner as every corner was slightly different.
    A decent book that got me through our house is: http://www.amazon.com/Tauntons-Trim-.../dp/B002B55XIG
    I'm not claiming there aren't better ones, just that that one was good enough to get me by
    17,475
    patti if you could post a picture of the area your trying to trim out that would be helpful in solving your troubles
    If the attachment works out, here's a photo of the hall. I suppose I could chop at random, since I messed up the trim on the first try by getting the cut wrong...I can tell you that a 45 degree cut on 90 degree corner molding will leave a big gap on both sides of the cut.
    What I want to do is trim out the left side and top of the hall, using 90 degree corner molding. I need to use corner molding to cover the gap, which is not consistent, on the left side of the hall.
    Thomasville, GA
    6,000
    If I'm seeing your photo correctly, you're using crown molding. The best way to cut crown is to place it upside down on your miter saw; i.e., the top of the crown on the table of the saw and the bottom on the saw fence. Leave the saw blade 90 to the table. Set the miter saw angle to half of the angle of your corner; i.e., 45 for a 90 corner. This works whether it's an inside or outside corner; saw blade moved left for inside corner or right for outside corner.
    Bill Arnold
    17,475
    bill she is using normal outside corner wood trim,, not crown molding.. i have done what your trying to do with 45 degree cut take a piece and cut it with a support block under it to get the 45 to carry threw correctly.. there maybe a out of square corner your dealing with which leads you to have more troubles with this.. just use a scrap piece pattie,, maybe someone could make a quick sketch up pic for you to see what i am trying to say
    Thomasville, GA
    6,000
    bill she is using normal outside corner wood trim,, not crown molding.. ... ..maybe someone could make a quick sketch up pic for you to see what i am trying to say
    Oops...I shoulda read more carefully - me and my one and a half eye! In the photo, it looks like crown is being added at the top of the wall and intersects an odd angle.
    Someone??? SketchUp pic? You sound like a good candidate!
    Bill Arnold
  1. Crown molding
    By Jim Evatt in forum General Woodworking Q&A
    Last Post: 07-12-2010, 10:33 PM
  2. cutting molding
    By ken lutes in forum General Woodworking Q&A
    Last Post: 04-07-2009, 11:49 AM
  3. molding
    Last Post: 11-17-2008, 05:06 PM
  4. Molding heads can be fun
    By Robert Schaubhut in forum New Tools
    Last Post: 09-04-2007, 02:40 AM
  5. Making molding
    By John Dow in forum Neander Woodworking Q&A
    Last Post: 01-26-2007, 03:58 PM
