- The Gorge Area, Oregon
Depends on the casters... Some (many, most) of them do have an annoying tendency to swivel/wiggle when you push on them even when they're "locked". I wouldn't expect that to affect the cut a whole lot but there is a safety issue, I sure wouldn't want a jointer to move when I was using it
I'd be more apt to use a flip up caster like: http://www.rockler.com/product.cfm?page=30842&site=ROCKLER - I'm pretty sure there is also a delta version that I can't find at the moment (and probably others, I've seen folks make their own with a board that flips down on hinges). That way the jointer would be solidly on the ground when using it.
Another option would be the great lakes leveling casters: http://www.greatlakescaster.com/products.php?cat=262 where the foot drops straight down from the attachment point. I have a set of those under a base on my bandsaw and they are rock solid once the foot is put down.
Larry's idea works quite good as well. If its to heavy for lifting the one end easily you could gin up a johnson bar (like the euro machines use) which you could make out of a 2x4 and a couple of wheels on the side with a piece of pipe for the pivot point. If you skip to 5:30 into this video you can see how a commercial version works: http://www.youtube.com/watch?v=E6NdUNM5QWA Thats an ~800+ pound machine and I can move mine easily from one side of the garage to the other with that setup.
FYI: speaking of jointers and loosing all your fingers, some jointer safety tips:
http://www.thewoodwhisperer.com/videos/fine-woodworking-jointer-safety/
We want to keep you with all your finger nubbs fully intact
