Results 1 to 10 of 10
Thread: Direct bury gas line?
    Floydada, Tx
    1,941
    I am going to add a gas line to the shop to keep it warm when doing finishing and glue ups. Main heat will be wood. Can anyone recommend what type of line to use for underground use?
    Call your gas company?
    Around here that is the one thing that I'm not allowed to do, have to call the gas company to do any gas line work.
    5,322
    Around here, they use an orange colored flexible plastic line that has a tracer/locator wire wrapped around it. It appears to be a flexible PVC. Plumbing contractors sell it in rolls, and it's about three times the cost of flexible water piping. A local plumber ought to be able to advise you.
    Jan 2011
    3,798
    Like Jim said, the flexible stuff is what's used most around here, easier to install than black pipe...check out 'Gastite' or 'Tracpipe' for a couple of examples...
    11,833
    I use just plain copper tubing. No codes out here but the lp gas company said I had to bury it at least one foot deep. We are supposed to use a special licensed plumber for gas lines too. But I did the connections myself to save the bucks. Gas company tests connections on first fill.
    Nov 2012
    Wapakoneta, OH
    611
    It may depend on how far you have to go....I know some folks have used a poly pipe for the buried part, but if the distance isn't too great I'd use copper (LP only). If it's nat gas yo may have to go with Gastite or such.
    This is what we just used in a house renovation in Houston http://www.gastite.com/products.php?...=ips_pe_tubing . Just make sure you bury a wire with it. We also used these to come out of the ground to attach to the meter and to transition into the house http://www.gastite.com/include/langu...TECH_SHEET.pdf
    When we had the NG heater put into the shop, the heating company recommended that I contact the utility company because they could make up a plastic line at a fraction of the cost that the plumbers working for the HVAC company could. I contracted the ditch dug, the untility company made up the line, the HVAC company installed the line and ran black iron inside the shop. The utiility company had the city inspector come out and inspect the final job.
    A few years later, when I hired a contractor to pull a new copper water line for me, the contractor cut the gas line between the house and the shop. He contacted the utility company. They came out and repaired the gas line going to the shop.
    Ken
    Floydada, Tx
    1,941
    Thanks all. Going to order some gastite line.
    Copper, while used for LP gas is not suitable for natural gas due to impurities in the gas which will eventually break down the copper and leak. It takes a few years but I see it all the time, working as a tech for a utility we light lots of water heaters that are almost choked off due to the black gunk from the inside of refrigeration copper. Years ago people saw plumbers using tin lined copper and didn't realize there is a difference and started making their own connectors out of it, tends to form holes where they flare the end for the fitting also.
  1. Peachtree Woodworking E-Direct Special Router top
    By John French in forum Hot Deals
    Last Post: 04-25-2012, 08:20 PM
  2. best sig line of the day (so far)
    Last Post: 10-26-2008, 02:07 PM
  3. Anybody know about Cummins Industrial Tools Factory Direct Sales?
    By Jay Lock in forum General Woodworking Q&A
    Last Post: 08-10-2007, 11:40 PM
