Results 1 to 10 of 16
Thread: Template routing question.
    13,361
    If you wanted to route a recess to hold a square plate, would you make a jig to use a bearing or a bushing?
    I'm leaning towards making one of Glens jigs and using a bearing.
    5,321
    I guess if you were able to make the recess in one pass you could use a top-bearing bit in a plunge router.
    My preference, if the recess is deep enough to require multiple passes - like anything deeper than about 3/8" - is to use a guide bushing and a straight bit designed for plunge cutting.
    Why not set it up for a bit with a guide bearing but cut it out first with a bushing and a straight bit. That way you get a nice clean final cut as the majority of the material has been removed.
    13,361
    Quote Originally Posted by Alan Bienlein View Post
    Now why didn't I think of that. That is actually perfect.
    I'm going to be cutting a hole for ventilation in my entertainment center.
    So the steps as I see it are:
    1. Create a template the exact size of my filter grill.
    2. Position the template on the workpiece.
    3. Rough cut the hole with a jigsaw
    4. Use a rather large bushing to clean up the hole.
    5. Use a bearing bit to cut the shallow recess to exactly the size of the filter screen.
    Thanks guys, That should do it just perfect!
    NH
    4,005
    Is it done yet?
    Stupid hurts.
    13,361
    Making some progress...
    NH
    4,005
    How bout now????
    Stupid hurts.
    13,361
    More progress, Not done.
    17,472
    hey chuck take a break and check back in a week or so
    13,361
    Just posted the latest progress in the entertainment center thread.
    I went with a disposable template. Didn't end up having all the other bits and pieces I would need to have finished the adjustable jig.
    Still like the idea of Glenns adjustable jig.
  1. Insert Bits for Template Routing?
    By Ted Calver in forum New Tools
    Last Post: 04-05-2015, 11:41 PM
  2. Template Routing Jig - v2
    Last Post: 12-12-2011, 12:47 PM
  3. Router template guide question...
    By John Pollman in forum General Woodworking Q&A
    Last Post: 01-29-2011, 09:12 AM
  4. CNC ROUTING ??
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 02-13-2009, 05:21 PM
  5. DC duct routing question
    By Doug Shepard in forum General Woodworking Q&A
    Last Post: 07-01-2007, 01:31 AM
