Results 1 to 3 of 3
Thread: Test charging of L-ion battery that won't take a charge
    3,134
    I have 2 18 volt Ryobi L-ion batteries same age 1 takes a charge the other doesn't.
    In a earlier thread it was mentioned that when a battery gets so low the charger won't charge it but if it is charged slightly the sensor in the charger may then pick up the trace current & charge the battery.
    Well I am trying this idea out. I taped a long screw in contact with 1 terminal & a short screw in contact with the other so that the clamps from the charger would be spaced apart I reinforced the electrical tape holding the screws with a thick rubber band. So far the light on the battery is now indicating that there is some current in the cells. I am using a battery trickle charger that I use to keep my Bobcat battery up over the winter it senses the battery charge & turns off & on the sustain the proper charge on the battery. If this works it will make me very happy .
    Austin, Texas
    1,448
    Sounds like a logical idea, but I would be really careful - If a Lithium Ion battery gets cranky, it simply catches fire. Ask the owners of the grounded Boeing Dreamliners. Ask the people who had a computer battery fail (I had two subject to manufacturer recall for overheating).
    Charlie Plesums, Austin Texas
    Oct 2009
    Dennison, MN
    512
    Quote Originally Posted by Charlie Plesums View Post
    Charlie is 100% correct. Modern batteries are basically dangerous when they are out of spec. Li-ion isn't super bad, but when you start getting into Li-Po and Li-Fe batteries they can explode with little to no warning. Especially the hard cased tool batteries. With the stuff I use for R/C, the batteries will get "puffy" when they are taking a crap on you, can't tell with tools.
    Most of the new batteries when the voltage drops too low, they are junk and are no longer charge-able. Most of the time there is a cut out in whatever the tool is that will shut it down once the cells are too low in voltage.
    For me, I wouldn't do it. Well, I'd do it in the shop, because its insured and I need a career change. :lol: But, being homeless from a fire would suck.
    "Do, or do not. There is no try."
    -Yoda
  1. Charging Station
    By Darren Wright in forum Flatwork Project Showcase
    Last Post: 02-29-2016, 03:48 PM
  2. What Would You Charge?
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 03-07-2014, 03:23 PM
  3. How much do we charge?
    Last Post: 10-29-2008, 12:09 PM
  4. Timers for battery charging stations...
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 12-28-2006, 02:19 PM
