Results 1 to 10 of 13
Thread: Arch rule
    17,470
    Arch rule
    well some time back i asked for the formula to make them and got some info that worked well and i still thought i could come up with something that didnt use brain power, that is sometimes in low supply here.. so i set out to find something without memory like wood has, well the plastic i had wasnt long enough and i think would have worked as well providing you dont go to thick on it, i had some 1/8" but not long enough so i dug up this from the local hardware, its 1/16th aluminum flat stock. just drill two holes one on each end and insert heavy cord to use for the knot end to adjust to arch your after. it has worked fine for the stuff i was after at the time.. and if i could get a longer one i would to make the larger archs. and at 4.00 dollars its pretty cheap and no brain power needed just align with your piece trace and you ready for the band saw
Name:	arch rule 001.jpg
ID:	73729Click image for larger version.
Name:	arch rule 002.jpg
ID:	73730Click image for larger version.
Name:	arch rule 003.jpg
ID:	73731Click image for larger version.
Name:	arch rule 004.jpg
ID:	73732Click image for larger version.
Name:	arch rule 005.jpg
ID:	73733Click image for larger version.
Name:	arch rule 006.jpg
    Dec 2008
    falcon heights, minnesota
    5,609
    good idea ol son!
    benedictione omnes bene
    www.burroviejowoodworking.com
    868
    It appears you saved yourself mucho moolah!
    http://www.leevalley.com/en/wood/pag...=1,42936,50298
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    May 2009
    Syracuse, Nebraska
    669
    That will work, but over time will take a set to bend to near the same setting every time. It's a molecular thing. However, if you alternate the side you are bending every time you use it, you will keep it in a flux state so the metal doesn't remember where it was the last time. That is why Polycarbonate works so much better. Eventually the metal will wear out for holding a true arc, but we all wear out eventually don't we? Basically, what I am saying is plastic has a memory and remembers it was flat and naturally wants to return to that state. Metal will take the shape you give it and remain close to that shape until you change it.
    13,357
    Great idea Larry. And I need one of these this weekend. I think I have something that will work in the shop already.
    Quote Originally Posted by Roger Newby View Post
    What if you store it flat and only bend it when you need it?
    Oct 2011
    Cortland NY
    238
    Would a steel yardstick work as well? it already has one if not two holes in it already. Nice idea either way.
    17,470
    it should, but roger says that poly carbonate is better,, but i had this so used it ed
    Thomasville, GA
    5,992
    Good idea, Larry!
    Bill Arnold
    13,433
    Nice little solution Larry, hadn't seen one using aluminum before. Wood had a fairing stick tip in a magazine a few years back with a piece on it to adjust the cord without tying a knot each time.
    http://www.woodmagazine.com/woodwork...fairing-stick/
    17,470
    went to thew link and that would work but that means i need more string i tried to watch the video and it wanted me to sign up to see them but i could watch a spindle being turned for free,, the whole world is trying to get me to do the spinny stuff
  1. 3-4-5 Rule
    By Darren Wright in forum General Woodworking Q&A
    Last Post: 03-25-2013, 11:54 AM
  2. LIDDED ARCH
    By Pete Gray in forum Lathe Project Showcase
    Last Post: 12-31-2012, 09:05 PM
  3. A small arch top wine cabinet
    By Robert Schaubhut in forum Flatwork Project Showcase
    Last Post: 11-17-2008, 12:59 AM
  4. How to draw an arch in SU?
    By Charlie Schultz in forum Designs, Plans and Sketches
    Last Post: 06-04-2007, 05:19 PM
