Results 1 to 10 of 18
Thread: Very Soft Sander?
    SE Minnesota
    2,526
    Very Soft Sander?
    A few weeks ago I made this drawing for a little cabinet with live edges. A very generous member whom I won't name (thanks very much, Larry) sent me some walnut with a live edge. The slope on the edges is much shallower than in my drawing which is fine but there's some neat little details--bumps and things like that which I want to keep. I want to sand off the remains of the bark and smooth the edge so it is pleasant to touch so I'm looking for suggestions for a sanding device. I started out sanding by hand and thought about backing the paper with a sponge of some sort but that won't help me get in around the details. What have you used that works?
    Haven't used one myself, but a sanding mop sounds like it might do the trick.
    Here's some already made:
    http://www.woodpeck.com/sandingmops.html
    And here are instructions for making your own:
    http://www.woodworkingtalk.com/f27/m...ing-mop-24022/
    SE Minnesota
    2,526
    Thank you. I took your word for it and ordered a mandrel and three different grits from Klingspor.
    We'll give it a shot.
    17,475
    a MOP is one of the best sanding rigs i have and am gonna get another for a different grit combo..they will work like a charm on that dave just dont push to hard and actually a high grit is better, that edge is soft.. a steel wire brush will get alot of it.. use a soft touch and you have great results..
    SE Minnesota
    2,526
    Thanks, Larry. We'll see what happens.
    Quote Originally Posted by Dave Richards View Post
    I started with a mop on the drill press. I do so many curves and irregular details on my stuff that I have morphed into this:
    4,699
    So.. What are we actually seeing there Glenn (i.e. what is the guts made out of)? Looks like a pretty nifty setup.
    13,361
    Those actually look like those old fashioned shoe buffers? Mounted, er, sideways? With longer spindles?
    17,475
    i think they are designed for buffing bowls guys,, and glenn just used sand paper mops instead.. look up buffing systems and you will find the motors withlong shafts//
    Two Shop Fox buffing mandrels and a 1HP motor on a stand / assembly I cooked up. I had to punch the sandpaper out to 3/4" to fit the shafts and had to reverse one of the shafts as they are situated back to back. Sorry for the thread jack Dave
ID:	73737 . Click image for larger version.
  1. getting soft hearted and soft headed!
    Last Post: 10-23-2013, 02:45 AM
  2. Just a soft grip pen
    By Brent Dowell in forum Lathe Project Showcase
    Last Post: 07-29-2013, 03:50 PM
  3. Soft sander
    By Bill McQueen in forum Jigs and Fixtures
    Last Post: 06-15-2011, 01:33 AM
  4. Soft Weights?
    Last Post: 08-14-2007, 11:12 PM
  5. Hard or Soft
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 01-10-2007, 08:58 PM
