Results 1 to 10 of 12
Thread: Planing down to 1/4"
    Feb 2012
    central florida
    208
    I think I need a sled to plane a board to 1/4" thickness
    Correct?
    Would a 3/4" plywood work for this ?
    11,832
    A sled would be needed. But describe more what you are trying to do. Maybe milling first would be a better approach.
    17,472
    frank is asking the right questions resaw might be your friend keith.. making two out of one board perhaps rather a bunch of shavings..
    What planer do you have. My lunchbox planer would go to 1/4" without issue. The floor standing machine tends to foul the trailing edge so I double-stick material to a piece of sheet goods so it won't lift up; melamine, MDF or good flat ply.
    Nov 2012
    Wapakoneta, OH
    611
    I've also planed to 1/4" without problems...but I won't go less than that without a sled.
    London, Ontario
    3,383
    Quote Originally Posted by fred hargis View Post
    +1 and +1 to Glenn's comments.
    I planed some 1/8" oak last month, just put some doubles-sided tape on a piece of 1/2" BB and fed it through the planer. I also reduced the amount that I planed on each pass.
    Dec 2008
    Santa Claus, In
    4,779
    I think you should be able to get to 1/4 no problem.
    Feb 2012
    central florida
    208
    Here is some more info.
    I have a 20" planer. grizzly/shop fox type. These are glue up panels around 14" wide and 19" long.
    I resawed some of the wood. Posted pictures of some practice wood I resawed because it was my first time. and it was great
    the wood is cedar.
    I have to be careful with the ones i want to make 1/4" thick because I only have 2 that I want to use and one i made for test fitting/planing. I have never tried less than 1/2" and if I remember correctly my height wheel started getting REAL stiff when I went that thin.
    I am also making 2 that are 3/8" inch thick and I will probably use the same method for the 3/8". I also have one practice panel in that size.
    May 2009
    Poway, CA, near San Diego
    174
    Having practice pieces is a great idea. But, I'd do some "pre" practice with a fence board or a piece of poplar. Just plane something down to 1/4" to see how it goes.
    Bob
    Feb 2012
    central florida
    208
    Quote Originally Posted by Bob Meyer View Post
    Bob
    I guess thats a good point. If it will do a narrow random board then it should do a panel.
  1. Planing technique
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 11-27-2012, 10:05 PM
  2. Face planing, I think.
    Last Post: 04-05-2012, 08:13 PM
  3. Drawer planing jig
    By Ian Gillis in forum Neander Woodworking Q&A
    Last Post: 01-07-2009, 08:16 PM
  4. Dummies and planing
    Last Post: 11-13-2008, 12:14 AM
  5. planing figure
    Last Post: 11-30-2006, 02:44 PM
