Results 1 to 10 of 12
Thread: Need some advice on staining this trim
    May 2009
    Lafayette, Indiana
    2,380
    I'm adding some simple pine trim to an area of my home. I have my pieces cut and fitted now I'm ready to stain them to match some cabinets. I'm using some Min wax wood finish. I cut myself a few "samples" of the trim to try my finish on in order to make sure it matched the excising stained cabinets. When I apply the stain I get this double shade of colors. The wood trim is not spliced or pieced together....this is just weird. My question is if I applied some wood sealer...would it stain more evenly?
    Photo is of the samples pieces. One stained and the other not. These were cut from the same trim board. You can see how the stained piece on the right is taking the stain in two different ways. Why?
Name:	IMG_0127 (Small).JPG
    5,172
    Pine needs sealing.
    17,471
    i am not sure its pine,, maybe its something else, popular maybe? but it acts like sapwood vrs heartwood
    Apr 2009
    Outside the beltway
    5,250
    2 things about what your doing.
    1. It does not look like pine.
    2. If it is and you want to match an old pine natural finish there is a simple way to do it. But I would want to if that is so befote I go into the procedure. If not you can seal it with 40 percent shellac 10 percent BLO
    AND 50 percent alcohol. Brush on , wipe off excess after a few seconds. Let dry and then stain.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    May 2009
    Lafayette, Indiana
    2,380
    I guess I assumed it was pine. Popular may be correct though. I may have a can of sealer somewhere. I'll give it a try
    NH
    4,005
    Pine needs sealing.
    Why do you say pine needs sealing?
    Stupid hurts.
    5,172
    The difference in the size of the cells between summer growth and winter growth is vast, so color absorbs differently. To achieve some uniformity, sealing is needed.
    May 2009
    Lafayette, Indiana
    2,380
    Is that what I'm seeing on this wood? Different growth cells?
    5,172
    Depends on the wood, Tom. The cell size is especially an issue with soft woods. Hardwoods that are face sawn, as opposed to quarter sawn, can present this problem too. The cell can be sliced at an angle that accepts more or less color. Sealing is easy and inexpensive.
    4,698
    For me I don't mind the color disparity but Pine also has a bad habit of blotching horribly across big sections of the board (due to slight variations in sanding quality or wood density or just plain pine in a pain). Even with "conditioner" I still have problems with pine blotching (I haven't tried Daves formula but odds are close to 100% that it would work better )
  1. A Staining Question.
    By Paul Douglass in forum Finishing School
    Last Post: 07-01-2014, 10:43 PM
  2. edging and staining
    Last Post: 03-07-2014, 07:08 PM
  3. Staining Red Oak ?
    By Wayne Ashing in forum Finishing School
    Last Post: 09-22-2009, 12:27 AM
  4. Trim Router Advice
    By Charlie Plesums in forum New Tools
    Last Post: 11-14-2008, 04:20 PM
  5. Glue-up after staining
    By Aaron Beaver in forum Finishing School
    Last Post: 11-27-2007, 05:36 PM
