Results 1 to 4 of 4
Thread: Sliding table for table saw
    May 2010
    Orland Park, Illinois, USA
    278
    Please share your thioughts/experience on the pros/cons of having a sliding table attached to your table saw. I am considering adding one but am not yet convinced of how/why it is better than a good crosssut sled. Thanks for your input.
    I have the jessum master slide that replaced a crosscut sled. For me it was the best thing I ever did.
ID:	73834Click image for larger version.
    I no longer need to find a place to store it and I actually gained in cross cut capacity. The other advantage is I don't have to worry about it tipping off the saw because of the size of my piece I want to cut. Then there's the built in scale and flip stops for up to 48".
    May 2008
    Deming, NM
    42
    I built a cross-cut sled. It was a pain to store, and put on and off the saw. Then I got a Mule 36" sliding table for the little contractor saw - much faster work. Then I saw this 48" slider in '94. Bought it and a used saw that it was made for. The difference? Most of my telescope or cabinet projects take 1/3 the time to build as they did without a slider. I can't recommend a sliding table enough…
    May 2011
    Cape Cod, Ma.
    1,553
    I have the excalibur sliding table attachment. Have had it for several years and in most instances it has replaced my chop saw. I do all my face frame cuts with it as well as my plywood cross cuts. Its been indispensible and well worth the investment!!
    http://www.amazon.com/GENERAL-INTL-E...+sliding+table
  1. 3hp 10 " cabinet saw and sliding table
    By Rich Soby in forum Classified Ads
    Last Post: 02-09-2016, 10:24 AM
  2. Sliding table
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 11-29-2008, 03:16 AM
  3. JST-48 Sliding Table - $460 (Not Mine)
    By Don Taylor in forum Hot Deals
    Last Post: 11-17-2007, 09:57 PM
  4. Sliding table for shaper
    By Doug Sinjem in forum Jigs and Fixtures
    Last Post: 11-16-2007, 02:47 AM
  5. PM66 with Sliding Table
    By Rob Bodenschatz in forum Hot Deals
    Last Post: 02-27-2007, 03:02 PM
Tags for this Thread
