Results 1 to 10 of 14
Thread: polyeurathane use after lacquer or shellac
    17,471
    ok have a possible project where the customer wants poly for finish.. i normally use shellac and or lacquer.. so what do i need to know before i fill my spray gun with this stuff? or should i just hand apply? they want a gloss finish.
    Portland, OR
    140
    Larry, Poly is going to dry much slower than lacquer leaving it open to collecting any airborne dust and such. Also, poly does not "build" like lacquer on additional coats. Yes, I would spray but very light coats.
    Doug
    5,320
    If you're asking about spraying poly over shellac, I've done it - with disastrous results! Even though I'd scuff-sanded the shellac, the poly didn't bond to it, and just peeled away.
    As for just using straight poly (no shellac under it), what Douglas said is correct. I'd also sand lightly between coats - and you'll likely only get one coat per day.
    BTW, the waterborne polys are pretty good, too, but I still prefer the solvent stuff when I've gotta use poly.
    3,134
    Doesn't poly need to have subsequent coats applied within a limited time or be rubbed down with 0000 steel wool or the like to give it tooth for the next coat to stick properly?
    17,471
    unfortunately this client has specs poly, i didnt even attempt to talk to him on lacquer.. should have.. is there a argument for ploy over lacquer? in my eyes there isnt.
    London, Ontario
    3,383
    Really?
    I put Flecto Varathane (which is a WB poly) over zinsser dewaxed shellac several times. Worked fine.
    I've sprayed it only once -- I was not thrilled with how slowly it built up, but it worked. Usually I make smaller projects and then I brush it on. 3-4 coats and it's hard and glossy.
    NH
    4,005
    Larry fetch your self some Ben Moor's water base and shoot it on. You can shoot 2 or 3 light coats than let it stand over night hit it with some 220 and shoot a finish coat on. Last time I used a cheap gun from HD I'm off to see how it goes through my new spray fine but I'm thinking the CV tip in the spray fine is to big for the polly. I'll let ya know in a few hours.
    Stupid hurts.
    NH
    4,005
    Fibbed to ya on the brand. I'm shooting ZAR but the shop is just a bit to cold for fast drying so we are waiting for the second coat. Guessing about an hour.
    Stupid hurts.
    NH
    4,005
    Ok second and third done. Now it's wait and see if I need to knock it down tomorrow and shoot it one last time.
    Stupid hurts.
    17,471
    keep me uniformed capt. we needs ta no
  1. Lacquer
    By Scott Turner in forum Finishing School
    Last Post: 05-15-2015, 04:28 PM
  2. shellac
    By Rex Bloem in forum Finishing School
    Last Post: 03-17-2011, 03:12 AM
  3. Lacquer over oil
    By Chris Krohn in forum General Woodturning Q&A
    Last Post: 05-18-2009, 12:49 PM
  4. where is the lacquer?
    Last Post: 08-24-2007, 03:30 PM
  5. What's up with my shellac?
    By M Toupin in forum Finishing School
    Last Post: 07-28-2007, 04:21 AM
