Results 1 to 3 of 3
Thread: DW734 Lock
    Apr 2008
    We now divide our time between southwest Florida and southwest Vermont.
    137
    DW734 Lock
    I have a DW734 planer with a Wixey thickness gauge mounted on it. Blades are sharp, and I'm not taking deep cuts. The machine is about three years old, with fairly light use.
    Lately, about a quarter of the way through the cut, the gauge will show a thickness change of a few thousands, as if the locking mechanism slipped a bit, causing the table to drop down. I can avoid the problem by setting the thickness with the crank, engaging the lock, and then cranking down an additional quarter turn. The gauge then holds the same reading throughout the entire cut.
    The lock does not seem particularly loose or easy to set, but I have a sense that it needs tightening. Unless I missed something, there are no instructions in the manual for adjusting it. If anyone has experienced this, or has any thoughts about it , I'd appreciate comments. The overall performance of the machine is fine, but I'm going to upgrade this spring and I'd like to address this issue if it needs attention before I offer it for sale.
    Tony
    The optimist says the glass is half full.
    The pessimist says it's half empty.
    I say the glass is twice as big as it needs to be.
    It is a friction mechanism. I had this issue with my DW-734 a couple times over the years I had it but, mine would sneak up due to pressure creating a thicker cut than desired. Raise the cutter head all the way, diligently clean the vertical guides with alcohol or naphtha, lower the head and clean the rest. To be sure you didn't carry more contaminants down when lowering the head, raise it again and clean again. Worked for me.
    Apr 2008
    137
    Glenn:
    Makes sense to me. I'll try that when we go North in April.Thanks.
    Tony
  1. Lock Your Cars!
    Last Post: 08-17-2012, 04:57 PM
  2. DW734 vs. DW735
    Last Post: 11-20-2010, 12:07 AM
  3. spindle lock
    Last Post: 10-24-2010, 07:42 PM
  4. Thermostat lock
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 02-22-2008, 10:08 PM
  5. Taper Lock
    By Jr Strasil in forum Neander Tool Questions and Show & Tell
    Last Post: 01-21-2007, 01:29 AM
