Results 1 to 10 of 23
Thread: Recovery
    13,443
    Recovery
    After digging a path by hand the length of the driveway in 10" of wet snow for my little tractor to take little bites at a time....
Name:	2013-02-26 17.38.19.jpg
    Equals this....
Name:	2013-02-26 17.53.42.jpg
    and this....
Name:	2013-02-26 17.51.26.jpg
    It was one of those wet sticky snows that clung to the trees. Took out power all over, lost our cable/internet for about an hour this afternoon.
Name:	2013-02-26 18.10.23.jpg
    If you would have just drank the regular instead of the light you could have skipped the ibuprofen!
    13,443
    Quote Originally Posted by Alan Bienlein View Post
    Probably added that extra weight I needed to keep the tires from spinning too.
    I did have to get "crafty" as I still don't have chains for the tires. I found a small chain I had around and cut two lengths just long enough to bolt the ends together around the tire through one of the rim holes twisted the chain to take any slack out and they did the job. As wet as it was I just couldn't get any traction at all.
    30,015
    Bummer.
    Equals this....
    Bummer.
    and this....
    Bummer.
    13,443
    Needed that.
    13,360
    Bwahahahahaha.
    I'd actually love to have that much snow. I think it'd be great to be snowed in for a few days. Not that it would change my lifestyle one bit.
    12,251
    Yeah Brent i used to think the same.
    We got the storm above us now.
    NH
    4,005
    To bad you are not a whole lot closer I have 2 or 3 different sets of tractor tire chains.
    Stupid hurts.
    13,443
    I appreciate that. I really haven't had a need for them. Most of our heavy snows have been under 3", these last two were just some record breakers we haven't seen in a while. I got lucky on the first one and only had one drift up by the shop, but this one was about 14" to 18" down the length of the drive.
    Do your rims have holes in them? If you you can make some temp traction cords out of some rope, they certainly won't last a long time, but they will work, just keep looping the rope through the holes in the rim and around the tire, then use something like a piece of coat hanger bent up to finish the cord off. They will not work as well as chains, obviously, but they will turn summer tires into something that will get some traction in the snow. You could also use big zip ties.
    I've done it on a motorcycle, but never on a tractor, I'm sure it would work, but I'm not sure how long it would last. Make sure it is a rope that you don't mind using up.
  1. Windows recovery WORKED!!!!!
    By Jim Mattheiss in forum Off Topic Discussion
    Last Post: 07-12-2009, 02:17 AM
  2. back injury recovery
    By Mark Kosmowski in forum Off Topic Discussion
    Last Post: 02-16-2009, 02:55 PM
  3. mallot recovery
    By Bill Simpson in forum Off Topic Discussion
    Last Post: 08-19-2007, 10:11 AM
