Results 1 to 10 of 12
Thread: Heavy Cabinet, Tile Floor, Your Choice of Feet?
    I have a buffet/hutch style cabinet in the works that will end up fairly heavy. The feet are simply the ends of the corner posts which I would like to keep close to the ground visually. The floor is a natural tile with the irregularities that go with that sort of material. The corner posts are about 2" square and I am thinking I will use a heavy commercial felt stick-on material small enough to be invisible from a normal observation position of standing or sitting in the room but, large as possible for load bearing. I would then shim if/where required, potentially with additional felt, the odd foot if such occurs. The elevation required for an adjustable foot will foul my floor to furniture line.
    Having said all that, what have you folks had success with for a heavy piece on a solid surface flooring when it comes to foot/pad material? TIA.
    Example at 1/8" which I prefer:
    Example at 1/4" which I think is too much:
    P.s. There will be a small chamfer around the bottom edge of the corner posts at the floor line.
    Dec 2012
    Bedford, NH
    1,683
    Would you entertain the thought of inleting the end of the posts to accept a piece of relatively hard rubber, say ~1 1/2" square x 1/8" thk, or other type of foot that you would prefer? The rubber would keep the cabinet from moving & the depth of the inletting could be adjusted, or shimmed if needed. Just a thought???
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Independence, Kentucky
    1,355
    Glenn I would counter bore the legs with a forsner bit, an insert a T nut and then use these levelers from Rockler. you would then have leveling capability and they would be mostly hidden
Name:	Screen shot 2013-03-01 at 8.02.30 PM.png
    Dec 2012
    Bedford, NH
    1,683
    Quote Originally Posted by Charles Hans View Post
    Now that's using your noggin!
    1,355
    Yhea, I tend to over complicate things I guess
    Good ideas one and all. I do have plenty of meat for a recessed cavity that would lower the profile of the adjustable feet and I have a collection of adjustable feet . . . hmmmm ;-)
    I had the same thought as Charles...hidden leveling feet.
    13,451
    I was going to suggest the same as Charles. Looks like there is enough girth there and as long as it's not getting dragged around moving it, they should hold up fine. I've got some of those 3 wheel furniture dolly's for moving heavy furniture, easy enough to lift one side an slide them under the feet so they don't drag when you move it too.
    Jun 2007
    4,944
    If you only have 1/8th of an inch clearance, how do you adjust the leveling feet? tip the cabinet, adjust a tiny bit, set cabinet back down, feel wobble and try again? Having spent fair amount of time leveling a TS and a router table, I think that would be a real deal breaker. I think I would rather have the rubber or whatever on the end of the 2x2 and then slide thin shims under the rubber (or whatever).
    You got my 2 cents worth. I hope it was worth at least that much.
    Enjoy,
    JimB
    VOTING MEMBER
    17,474
    glenn use charles idea but get a block of 8/4 glue up and do your cutting of the forstner in that and just glue that to the inside corner and hidden, will strengthen the leg area alot..3 or 4 " high block is fine.. cant get to my pics now so if you dont understand my words holler
  1. Tile saw
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 11-10-2012, 09:31 PM
  2. Ugly Tile Floor
    By Cynthia White in forum Carpentry and Construction
    Last Post: 03-25-2011, 10:49 PM
  3. Which Came First The Cabinet Or The Floor?
    By Kevin Brown in forum Carpentry and Construction
    Last Post: 07-29-2010, 02:15 PM
  4. Old radio cabinet redo - in process- Pic Heavy!
    By John Bartley in forum Flatwork Project Showcase
    Last Post: 03-15-2010, 08:23 AM
  5. Small Wall Cabinet - Pic Heavy
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 12-02-2009, 10:53 PM
