Results 1 to 3 of 3
Thread: Danish oil finishing
    Hello all,
    I would like to try finishing with danish oil. While searching the net, I came across this step-by-step process. Does it look accurate to those who have used danish oil?
    http://www.ehow.com/how_4448639_fini...anish-oil.html
    So mote it be.
    http://www.SCAregalia.com - Masonic regalia and supply
    Save 10% with the code: BROTHER
    4,701
    Close enough. Its about as fool proof of a finish as you can apply so its nice for those of us with low-no finishing facilities (and commensurate skills, speaking only for myself ).
    I tend to wipe off the first coats a smidge more aggressively than they suggest but its within the noise. It doesn't really build on the surface to speak of so its not good for anything that will see a lot of wear (nor will it hold a super high gloss, some wax on top can make up for some of this). For higher wear items I use mostly use wiping varnish which I apply in about the same way.
    Nov 2012
    Wapakoneta, OH
    611
    I agree. I've never used the Watco product, but the application is about the same. I make my own with 1/3 each: BLO, varnish, MS.
  1. Danish Oil on Pine?
    By Tom Wallace in forum Finishing School
    Last Post: 05-22-2015, 10:04 PM
  2. Danish Modern?
    Last Post: 07-14-2014, 05:37 PM
  3. Danish oil question
    By Jerry Strojny in forum Finishing School
    Last Post: 12-06-2011, 02:51 PM
  4. Danish Oil Not Curing?
    By Vaughn McMillan in forum Finishing School
    Last Post: 04-21-2010, 04:18 AM
  5. Watco Danish Oil
    By Aaron Beaver in forum Finishing School
    Last Post: 12-23-2007, 07:20 PM
